speed Calculations
Results 1 to 19 of 19
    Feb 2012
    PERTH AUSTRALIA
    Default speed Calculations
    Hi guys ,
    i need to do some simple speed calculations in PBP 3 on 18f67k22 pic , that is very very full PIC already.
    i have not had to do floating point calculations before and not sure if i need to now for this but i suspect i do, hope i dont cos i believe the overheads can be high .
    i have options / variables that select the following for the displayed / recorded results
    Display Distance base measurement
    00 = Feet
    01 = meters
    02 = miles
    03 = KM
    Display Time base measurement
    00 = time in sec
    01 = time in minutes
    02 = Time in Hours
    03 = LAP SPEED
    Distance input values
    0 - 4000
    Time input values
    days, hours , min, sec , 1/100th
    i would like to display the speed for the selected option , with a result to 2 decimal places
    can you advise the best way to get this started for the least likely overhead in code space
    Cheers
    Sheldon
    Sep 2009
    Default Re: speed Calculations
    You didn't give range of variables...
    One way is just multiply distance with 100, and put decimal separator fixed on display in result, if long variable have range to do that...
    Feb 2012
    PERTH AUSTRALIA
    i cant see multiy by 100 is going to help
    speed = distance / time
    also cant see how i can avoid floating points and longs again ;(
    distance = distance base measurement ( feet or meters or km or miles ) x distance input value
    time = time base measurement ( sec or mins or hours or lap count ) x time measured value
    for the caclulation of distance i though convert all values to meters as common base value
    if meters option then Distbase_value = 1 ' = 1 meter
    if feet option then Distbase_value = 3.28 ' = feet to meters
    if Km option then Distbase_value = 1000 ' = 1 km in meters
    if Miles option then Distbase_value = 1609.34 ' = 1 mile in meters
    Dist_input = 0 - 4000
    Distbase_value x Dist_input = Distance ' 24 bit number max ???
    Calculation for Time base - make a sec the common base to work to
    if sec option then Timebase_value = 1 ' = 1 sec base
    if min option then Timebase_value = 60 ' = 60 sec in min
    if hour option then Timebase_value = 3600 ' = 3600 sec in hour
    TimeValue = days/hours/min/sec /1_100th - convert time to secs base
    timevalue = days x 24 x 60 x 60 ' days
    timevalue = timevalue + (hours x 60 x 60) ' hours
    timevalue = timevalue + ( mins x 60) ' mins
    timevalue = timevalue + sec ' sec
    timevalue = timevalue + (100th / 100) ' 1_100th
    timevalue eg 12456.78
    timebase x timevalue = Time
    speed = distance / time ' speed is a max 32bit positive number
    is this seem right or am i doing the long and hard way , with larger number than need to
    i am just starting to read up on Floating point , with the include of "FP1832.bas" and what i think is required as well , but not sure where to put them yet in the program of Fp32.A18 and math18.inc files
    sheldon
    Sep 2009
    By multiply your number with 100 you shift result for 2 decimal places.
    Eg:
    10/3=3.333
    If you are using integer, result is 3.
    If you multiply 10 with 100, (10*100)/3=333.333, using integer's result is 333. Put dot on in front of second digit, and displayed result is 3.33. And you get your result with 2 decimal places.
    This is explained too many times when using ADC to display voltage on input...
    would it not be easier to decide on a basic speed unit first ie miles/hour , kph or meters/sec.
    even yards per month or whatever then just convert it to the desired display format
    for my money i'd pick meters/second
    Feb 2012
    PERTH AUSTRALIA
    id like to use sec/meters as the only option but i dont know what option is to be used on the day , and must allow for each possible one described
    and
    1 m/s = 2.236936292054402 mph =3.3 kph =1.943844492440605 knots=3.280839895013123 ft/s =0.0029386414601757 mach ................................
    to have any chance of doing this efficiently we need to know
    min and maximum for each of these quantities
    1 velocity
    2 distance
    3 time
    otherwise its just pissing in the wind
    as a surprise ...
    1 foot = 78/256 meter
    1 mile = 412/256 kilometer
    Which are more than easy to calculate in PBP ...
    others are obvious ...
    Feb 2012
    PERTH AUSTRALIA
    1 velocity
    2 distance
    3 time
    velocity - max = 300km /hour
    distance input max = 4000 ,
    options of distance base is miles/km/meters/feets
    timer allows for 7days 23hours ,59mins, 59,sec,. 99 1/100th - before rolling to 0.00
    timer base for speed measurments is sec, min, hour,
    1. so worst case
    max distance 4000 miles = 6437376 m
    max time = 8 days = 69120000 1/ 100's of a second
    v=(d/time)/100 (d in meters ,time in 1/100's of a second) = v in m/s
    velocity= (6437376/69120000) /100 (to two decimals) as m/s
    velocity= (6437376/69120000)*36 /1000 (to two decimals) as kph
    and using Alain's figures
    velocity= (6437376/69120000)*256 /(100*78) (to two decimals) as ft/s
    etc.....................
    just keep within the range of unsigned longs
    a better strategy would be to examine the magnitude of the time and switch to hours at a suitable size and ditto for distance switch to kilometres for larger distances. you may be able to avoid longs
    that way
    Thumbs up Re: speed Calculations
    that way
    +1000
    and moreover if only two decimals are needed for the result ...
    might be the " Arduino syndrom " ( extensive use of floats ) ???
    Feb 2012
    PERTH AUSTRALIA
    yes like to avoid longs if i can for code space
    Feb 2012
    PERTH AUSTRALIA
    btw u pic a good horse today richard
    could not even get last in the sweep
    Feb 2012
    PERTH AUSTRALIA
    in a starting point i am trying to "include FP1832.bas" , into the program with fp32.a18 , math18.inc in the programs working directory , but getting lots of asm errors symbol not prev defined 113 as a result , what am i forgetting ?
    Feb 2012
    PERTH AUSTRALIA
    i would love to avoid floats or long at all , which means a lot more if/then for ranging of the inputs for the distance and time options for a given time / distance input
    the result display would be returned to 1 byte for decimal display use , and a word value for the above decimal use ,
    i am bit lost on this one on how to get it going atm would not be too bad normally but i have only small amount of code space left , i am still trying to claw back some code space elsewhere
    varables i have so far
    Display Distance base measurement selection option
    00 = Feet
    01 = meters
    02 = miles
    03 = KM
    Display Time base measurement selection option
    00 = time in sec
    02 = Time in Hours
    03 = LAP SPEED
    0 - 4000 - 2 bytes
    Time input values
    days, hours , min, sec , 1/100th - all 1 bytes
    one of the first rules in mathematical calculations is that 2000/2.xx is accurate to 0 decimal points
    2000.0 / 2.xx is accurate to 1 decimal point. to be accurate to 2 decimals all!! input figures must be measured to two decimals , otherwise its fantasy
    actually its worse than I made out
    see this
    http://courses.chem.indiana.edu/s117...on-SigFigs.pdf
    Feb 2012
    PERTH AUSTRALIA
    that was interesting read and a worry in how calculations can go astray , i guess i am looking for no better than if i put distance / time into online calc i get it to 2.dec places , as best as possible
  1. CRC Calculations
    By timmers in forum mel PIC BASIC Pro
    Last Post: - 16th June 2009, 17:10
  2. clock/timer calculations
    By virolay in forum mel PIC BASIC Pro
    Last Post: - 4th January 2008, 20:20
  3. Incorrect calculations... please help.
    By bearpawz in forum mel PIC BASIC Pro
    Last Post: - 29th January 2007, 22:03
  4. Calculations for using faster Clocks.
    Last Post: - 18th April 2005, 14:24
  5. timing calculations
    By scorpion in forum mel PIC BASIC Pro
    Last Post: - 28th November 2004, 22:58
