How to detect low battery in battery powered F683 circuit
Results 1 to 32 of 32
    Sep 2008
    Maine, USA
    Default Re: How to detect low battery in battery powered F683 circuit
    Quote Originally Posted by mark_s View Post
    I think you would declare your variable as
    GreenLED var PORTA.1
    Been testing that and the compiler seems to accept either
    or
    GreenLED var LATA.1
    "Do or do not, there is no try" Yoda
    At this point without posting your complete code it's hard to guess what's wrong.
    Sep 2008
    Maine, USA
    Got all the OUTPUTS working fine - no need for LATA configurations apparently. Struggling with some kind of hardware bug - so I'm basically good. No idea how or why I would configure LATA at this point as it all seems to work fine without any direct reference to it.
    SWITZERLAND (french speaking)
    Default MICROCHIP's an1072
    Maybe this application note from MICROCHIP can help ;-)
    Roger
    I did this a long time ago with a 6V circuit. The pic was running from the battery (with a series diode = 5.4V) but there was a 3.3V regulator elsewhere on the circuit board. I ran a jumper wire from an ADC pin to the 3.3V reference voltage. As the battery voltage begins to drop, the ADC reading will begin to rise. When the ADC reading reached the desired point, the SOUND command alerted you.
    I just realized I posted the above last October.
  1. How can a battery powered PIC turn itself off?
    By tekart in forum mel PIC BASIC Pro
    Last Post: - 9th August 2012, 10:44
  2. Replies: 13
    Last Post: - 22nd January 2012, 04:48
  3. Battery powered applications
    Last Post: - 22nd June 2009, 07:12
  4. 12F683 battery powered remote - energy consumption question
    By silentwol in forum mel PIC BASIC Pro
    Last Post: - 13th April 2007, 13:23
  5. Battery Powered Need Help!
    By scottl in forum Off Topic
    Last Post: - 29th March 2006, 09:52
