ADC setup on 12F1822 ??
Results 1 to 9 of 9
    Mar 2008
    Default ADC setup on 12F1822 ??
    Hello!
    Has anyone been successful on getting data from the ADC on a 12F1822? While I can get 8-bit conversions, I cannot get 10-bit results. I have puzzled through the related registers from reading the data sheet. Briefly, I find that setting ADCON1.7 stops the ADC from working. Clearing ADCON1.7 lets it work in 8-bit mode.
    Reading the errata sheet they show problems with the ADC, and a possible workaround, but I'm not convinced that is my problem since the problem also occurs on a 12F1840.
    I can post example code, but initially I just wanted to know if someone on the forum is able to get 10-bit data from a 12F1822, or a 12F1840.
    Thanks!
    Default Re: ADC setup on 12F1822 ??
    works for me
    cfg1 = _FOSC_INTOSC
    cfg1&= _WDTE_ON
    cfg1&= _PWRTE_OFF
    cfg1&= _MCLRE_OFF
    cfg1&= _CP_OFF
    cfg1&= _CPD_OFF
    cfg1&= _BOREN_ON
    cfg1&= _CLKOUTEN_OFF
    cfg1&= _IESO_ON
    cfg1&= _FCMEN_ON
      __CONFIG _CONFIG1, cfg1
    cfg2 = _WRT_OFF
    cfg2&= _PLLEN_OFF
    cfg2&= _STVREN_ON
    cfg2&= _BORV_19
    cfg2&= _LVP_OFF
      __CONFIG _CONFIG2, cfg2
    DEFINE ADC_BITS 10 ' Set number of bits in result
    DEFINE ADC_SAMPLEUS 50 ' Set sampling time in uS
    ADCON1=$f0      'rc clk vdd ref   right justify
          osccon=$6A    '4 mhz
          anselA=1       'dig i/o
            ' CMCON0=7        ' compare off
          trisA=001
      adval var word
      pause 5
       ADCIN 0, adval
     lata=0
     if adval > 500 then lata.2= 1 'led1
     if adval> 200  then  lata.1=1' led2
    Mar 2008
    Thanks ^^^
    I am doing the same register setups as you show, except that I'm using AN2 (ANSELA=%0100, TRISA=%01100). In addition I have ADCON0.0=1 (enable ADC). I'll try removing this. I'll work on this and post my results.
    Thanks again!
    ADCON0.0=1 serves no purpose the ADCIN code will do that for you
    This may be obvious but since you didn't post your code I'll say it anyway.
    The variable you're putting the result in is declared as a WORD, right?
    looks like "Occam's Razor" may have struck again
    Mar 2008
    ... The variable you're putting the result in is declared as a WORD, right? /Henrik.
    Yes, it's a WORD. But thanks!
    Sep 2008
    Maine, USA
    Not sure if you figured this out, but 10bit AD need to be read out as RIGHT justified, and 8 bit reads should be LEFT justified. Here's a config that works for 8-bit:
    ADCON0.0 = 1 ' AD ON
    ANSELA = %00000001 ' select analog vs digital (1=analog)
    ADCON1.7 = 1 ' bit7 = 1 = LEFT justified
    define adc_bits 8 ' set ADC as 8 bit
    "Do or do not, there is no try" Yoda
    Mar 2008
    Thank you^^^. Yes, I got it sorted out. I think my initial confusion resulted from some interaction between PBP3 DEFINEs for the ADC module and some direct settings I was also doing on some ADC-related registers. Everythings good now. Thanks again!
  1. Help to setup ADC for 16F1826
    By SOTASOTA in forum mel PIC BASIC Pro
    Last Post: - 12th February 2014, 00:06
  2. 12F1822 troubles
    By Charlie in forum mel PIC BASIC Pro
    Last Post: - 24th June 2012, 12:53
  3. 12F1822 embedded host?
    By dhouston in forum USB
    Last Post: - 18th September 2011, 18:14
  4. MIBAM and 12F1822...
    By alesniak in forum mel PIC BASIC Pro
    Last Post: - 17th September 2011, 06:45
  5. ADC setup for 16F716
    By droptail in forum mel PIC BASIC Pro
    Last Post: - 12th November 2009, 02:39
