Random…. More like a scripted Sequence !!!
Results 1 to 11 of 11
    May 2012
    Merseyside, UK
    Default Re: Random…. More like a scripted Sequence !!!
    Hi all.
    Thanks for help / ideas.... been playing with a couple. Seems to be a lot of repeat numbers... Maybe that just me looking to hard into it.
    I really thought multiplying the seed number by two different prime numbers would help..... ! It must mustn't it ?
    BR
    Andy
    Hi Andy,
    If you give it a certain seed value you'll get a certain "random" sequence of number and that sequency will be the same every time you give it that particular seed value. Mutliplying any seed value by a constant number (prime or not) will only result in a sequence of number like if you've given it that particular seed number from the beginning - it won't make it more random. It may even be so (easy to check) that the seed value is actually only a pointer into the sequence of numbers, ie where to start in the static sequence of "random" numbers.
    For something like a dice whice involves human interactin you have the best "random" generator available in the form of time. Let a timer free run and just grab its value when a new number is needed. There's no way a user is going to be able to "pick" a certain number.
    Sep 2008
    Maine, USA
    Almost all CPUs (including PICs I think) use a simple logic circuit known as a "pseudo random number generator". It is basically a shift register that feeds back on itself producing a finite series of random numbers. In the pic I believe it is around 36K words long, but I may be wrong. Here is a good article about this:
    http://www.maximintegrated.com/en/ap...ex.mvp/id/1743
    One of my tricks for generating random numbers is to read ambient light using a photocell and a resistor to create a divider. This feeds into any A/D input with as much resolution as you need.
    I have also successfully used pedja089's solution of timing intervals between button presses if they are frequent enough.
    "Do or do not, there is no try" Yoda
    May 2012
    Merseyside, UK
    Interesting read Tekart..
    Will have a play with the LDR (PhotoDiode) on the ADC.... Sounds like it might work !!
    Thank you all again
    Andy
  1. Replies: 13
    Last Post: - 5th September 2010, 02:55
  2. How to set sequence of interrupt for PIC
    Last Post: - 21st June 2008, 12:17
  3. FOR sequence is skipped
    By selbstdual in forum mel PIC BASIC Pro
    Last Post: - 10th August 2006, 03:35
  4. Installation sequence
    By Demon in forum General
    Last Post: - 11th July 2006, 04:56
  5. Switch Sequence
    Last Post: - 13th February 2005, 21:36
