Random…. More like a scripted Sequence !!!
Results 1 to 11 of 11
    May 2012
    Merseyside, UK
    Default Random…. More like a scripted Sequence !!!
    Hi all thank you for reading..
    MyWord var Word
    MyByte var Byte
    Random MyWord
    MyByte=(MyWord//6)+1
    Using the above basis I have created what I thought to be a "Dice" type program to give me a "random" number between 1 and 6… however I have just found the resulting output is scripted (Not Random). Has anyone else discovered this random bug, or is it just me…. ???
    Default Re: Random…. More like a scripted Sequence !!!
    from the manual
    RANDOM is not a true random-number generator. It performs a complex math
    operation on the seed value, resulting in a "seemingly random" result. The same
    seed value will always yield exactly the same result. If the result is used for the
    seed value in subsequent iterations of RANDOM, the result is a predictable
    repeating sequence of numbers.
    what some do is seed the random with a adcin reading on a unconnected analog pin
    eg
    adcin ch,myword
    random myword
    worth trying ?
    ps unconnected = floating
    Apr 2011
    Welches, Oregon
    It is not a bug. Computer systems of all types are, at their core, logic devices - incapable of random or chaotic operation. More complex systems simulate randomness by "seeding" their random generator with, perhaps, the bit-sum of some area of uninitialized memory or an algorithm based on the time and date. In this way they start the "random" sequence at an unknowable (but calculated) location - this gives the appearance of randomness, but is not.
    On such a simple system as the PIC, this "seeding" is left to the designer. You might, for example, loop from 0 to the current value of Timer1 before selecting your "random" value - unlikely "rolls" will be so perfectly timed as to make the outcome calculable.
    May 2012
    Merseyside, UK
    Cool Re: Random…. More like a scripted Sequence !!!
    Hi all the trick of using the ADC port worked great..... Well for what I need anyway. Added to my little books of tricks ..
    Only issue was the 628 I was using didnt have ADC so migrated to a 818.
    Thank you again...
    May 2012
    Merseyside, UK
    Unhappy Re: Random…. More like a scripted Sequence !!!
    Further to this thread...
    Although using :-
    adcin ch,myword
    random myword
    I am using the same ADC port to create 2 random numbers....:-
    adcin 4,myword1
    random myword1
    adcin 4,myword2
    random myword2
    Altough the sequence is random..... I am getting repeats (the two myword results are the same)....!
    Is it doable to multiply/ divide/ add the myword by a number to change iton one of the words:-
    adcin 4,myword1
    myword1=myword1*7 ' (myword2=myword2*5 for second one)
    random myword1
    I have tried the above and differing variables of it ..... But I still get the repeating outputs. Channel 4 is the only ADC channel spare enough to be doing nothing.
    Thank you again for reading. Hope it makes sense
    Andy
    Sep 2009
    If you have some user input on pic, you can use that for seed value by measuring time between button press and release. But again RANDOM just use some math and probably after some time repeat result.
    For dice I used this code:
    For i = 1 to 6
    If button=pressed Then GoSub ShowResult
    Next i
    GOTO Main
    That is closest to random as you can get it. Result depending only on user button press. Variable will change value about 200 000 times in one second, so there is no way to repeat sequence...
    If the ADC aproach isn't working then using one of the PICs timers in freerunning mode to provide the seed might do it. For this to work the execution of time between each instance of the random instruction must not be constant.
    May 2012
    Merseyside, UK
    Hi all.
    Thanks for help / ideas.... been playing with a couple. Seems to be a lot of repeat numbers... Maybe that just me looking to hard into it.
    I really thought multiplying the seed number by two different prime numbers would help..... ! It must mustn't it ?
    BR
    Andy
    Hi Andy,
    If you give it a certain seed value you'll get a certain "random" sequence of number and that sequency will be the same every time you give it that particular seed value. Mutliplying any seed value by a constant number (prime or not) will only result in a sequence of number like if you've given it that particular seed number from the beginning - it won't make it more random. It may even be so (easy to check) that the seed value is actually only a pointer into the sequence of numbers, ie where to start in the static sequence of "random" numbers.
    For something like a dice whice involves human interactin you have the best "random" generator available in the form of time. Let a timer free run and just grab its value when a new number is needed. There's no way a user is going to be able to "pick" a certain number.
    Sep 2008
    Maine, USA
    Almost all CPUs (including PICs I think) use a simple logic circuit known as a "pseudo random number generator". It is basically a shift register that feeds back on itself producing a finite series of random numbers. In the pic I believe it is around 36K words long, but I may be wrong. Here is a good article about this:
    http://www.maximintegrated.com/en/ap...ex.mvp/id/1743
    One of my tricks for generating random numbers is to read ambient light using a photocell and a resistor to create a divider. This feeds into any A/D input with as much resolution as you need.
    I have also successfully used pedja089's solution of timing intervals between button presses if they are frequent enough.
    "Do or do not, there is no try" Yoda
    May 2012
    Merseyside, UK
    Interesting read Tekart..
    Will have a play with the LDR (PhotoDiode) on the ADC.... Sounds like it might work !!
    Thank you all again
    Andy
  1. Replies: 13
    Last Post: - 5th September 2010, 01:55
  2. How to set sequence of interrupt for PIC
    Last Post: - 21st June 2008, 11:17
  3. FOR sequence is skipped
    By selbstdual in forum mel PIC BASIC Pro
    Last Post: - 10th August 2006, 02:35
  4. Installation sequence
    By Demon in forum General
    Last Post: - 11th July 2006, 03:56
  5. Switch Sequence
    Last Post: - 13th February 2005, 20:36
