identifying text commands
Results 1 to 4 of 4
    Oct 2014
    Default identifying text commands
    I need to have my microcontroller act upon different commands sent. For example if "GC" is sent it turns on a motor. If "GQ" is sent it sends back data.
    I would expect it to be something like this, as many other BASIC languages use:
    hserin [command]
    if command = "GC" then ....
    if command = "GQ" then....
    where the text inside the parentheses is what is compared. How is this done in PicBasic?
    WAIT kind of does that but if I understand its operation correctly the program is suspend waiting for the text string. I need to check to see if anything was received and if so act on it but if not go do other things. I can't suspend everything and wait.
    A STRING variable type would be handy.
    Default Re: identifying text commands
    PBP doesn't have a string type variable per se but it does have array type variable which is pretty much the same thing.
    If all your commands are two character command then declare a 2 byte array, like
    command VAR BYTE [2]
    Then, once you have the command IN the array you can, for example, do something like
    IF command[0] = "G" AND command[1] = "C" THEN
      ' Do Whatever
    IF command[0] = "G" AND command[1] = "Q" THEN
      ' Do Whatever
    This is a pretty straight forward way, depending on the number of different commands there might be "cleaner" and/or more efficient ways of doing it.
    Sep 2010
    Las Vegas, NV
    I'm just curious if PBP could differentiate between caps and lower case? i.e.
    Would this:
      ' Do Whatever
      ' Do Whatever
    Produce the same results as this:
    IF command[0] = "g" AND command[1] = "c" THEN
      ' Do Whatever
    IF command[0] = "g" AND command[1] = "q" THEN
      ' Do Whatever
    If this is too elemental of a question I apologize for any inconvenience.
    Sep 2009
    It's not same...
    Take look at ASSCI table
    http://www.asciitable.com/index/asciifull.gif
    "G" and "g" are just constant. You also could write 71 instead of "G", 103 instead "g".
    is same as
    IF command[0] = 71 AND command[1] = 67 THEN
    For parsing string commands I use this:
    http://www.picbasic.co.uk/forum/show...009#post117009
    Scroll down code to CommandParser: label.
    You can easily convert upper case to lower and lower to upper as in this sample
    http://melabs.com/samples/PBP-mixed/serin.htm
  1. Need a connector identifying
    Last Post: - 24th June 2012, 19:03
  2. How to prepare text (lots of text) for HSEROUT ?
    Last Post: - 15th February 2010, 22:31
  3. Identifying which port to use
    By fadibasic in forum Schematics
    Last Post: - 24th April 2008, 02:21
  4. Help Identifying Mystery IC
    By paul borgmeier in forum Documentation
    Last Post: - 28th May 2007, 05:20
  5. Replies: 0
    Last Post: - 28th May 2004, 17:25
