Life after 2k w/ 16F648
Results 1 to 15 of 15
    Dec 2003
    Wichita KS
    How about a interupt??
    Maybe a wrong return on a interupt (Like a Goto Start), instead of not returning on the GoSub?
    I was looking at your code....
    What happens if A = Value? and that IF statement fails?
    It goes right through 16 times, and then continues to the Subroutine...hits REturn... and...and...<g>
    DWayne
    Ability to Fly:
    Pilots that are Flying:
    Dec 2003
    Wichita KS
    Hello Ace,
    Ace
    For I = 1 to 16....
    GOSUB Thesub
    PULSIN input,1, value
    IF (value < A) OR ( value > B ) then
    error = 1 ( it's a red led ! )
    value1 = ...
    value2 = ...
    GOTO Start
    result = result + value
    NEXT I
    result = result >> 4 ( the mean value ....)
    REwrite it as the following:; I think this will solve your problem...This is assuming you have a goto start BEFORE your subroutine...like after your
    result = result >> 4 ( the mean value ....) statement.
    i=1
    while(i<17)
    GOSUB Thesub
    value1 = ...
    value2 = ...
    i=18
    I=I+1
    endwhile
    if I>18 then goto start
    Ability to Fly:
    Hi, Bruce
    The "GOTO Start" has to be here to allow a pulsout for each value of I ....
    It works very well with no FOR -NEXT loop ...
    But there's another problem on the line past "result = result >> 4" :
    ( with >> 4 neutralised ...of course !!! )
    IF ABS ( result - refvalue ) > 100 THEN Start
    Whatever the value of result ... test result is YES !!!
    So, I begin to think the problem is located on the IF THEN tests ...
    Note this works with R/C signals ... 1 to 2 ms pulses @ 40 Hz
    Hi, Dwayne
    There are no interrupts in all the programs i've written at this day ...
    for these types of programs, all is driven by the incoming ( or not !!! )signals ...hope it will last !!!
    I want to tell once more this piece of basic litterature has been running perfectly for years on smaller programs aboard dozens of 16F628s ... with the same names for variables ...and the same working context.
    IF value between A and B ... it is simply considered good and taken for the mean value calculation ... with no spare value for pulsout generation, nor calculation reset.
    If you look hard at the logic, you'll see what's happening. It can never get
    through the FOR/NEXT loop any time your IF/THEN block evaluates as TRUE.
    When this happens, as you mentioned previously;
    If result = ...THEN" test always passes
    That is exactly what causes this;
    placed in a FOR NEXT loop ... program hangs up !!!
    Because GOTO Start is inside your loop, inside the IF/THEN block that always
    evaluates as TRUE.
    Start:
      result = 0
    For I = 1 to 16....
      GOSUB Thesub
      ' If this next part "always" evaluates TRUE, then you'll never make it
      ' past FOR I = "1". You keep jumping back to Start & restarting
      ' the FOR/NEXT loop
         value1 = ...
         value2 = ...
         GOTO Start  ' <-- restarts FOR/NEXT loop over & over & over, etc,,
       ENDIF           ' while IF/THEN evaluates as TRUE
    NEXT I
    TheSub:
       Low out1
       Pulsout out1,value1
       Low out2
       Pulsout out2,value2
    Now let's assume the statement IF (value < A) OR ( value > B ) then
    never ends up being TRUE. You go through the FOR/NEXT loop until it expires,
    fall-through into TheSub, land on the RETURN, and you now have another big
    problem.
    RETURN pops the return address from the stack. Where is your program going
    to return to if the address is invalid...?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Talking
    Hi, Bruce
    You'll laugh ... that's exactly what I'd like the program to do !!!
    let's see closer :
    if value is between A and B ... test fails and program computes the mean value. That runs well.
    if value is out from A to B , it means signal is out of limits ( Wrong signal ) or no signal at all ( pulsin returns 0 - note pulsin_max defined 12500 @ 20 Mhz).
    Then, loop is supposed to be endless and generating spare signals to outputs until a correct input signal is found.
    I had a closer look lighting a led as a "pass flag": Even with no incoming signal at all, test for value never comes true ... led do not light up when High led is placed
    right after "value2 = ..."
    But the Pulsin statement is run well.
    Note between the end of this bit of program and the sub, there's a goto to the "good incoming pulse section" ...
    If you want the full prog. ( source is ~ 500 lines ...) to have a better view, it will be without any other than the copyright limitations.
    The most confusing thing is those lines ( they are Copied and pasted from other program ... with same variables !!! ) work perfectly on shorter programs aboard 16F628s.
    As I told Dwayne, an IF THEN statement placed after those lines also always returns YES. ...
    EVEN values must return NO ...
    I seriously think the problem is located in the IF THEN tests ( all the tests... )as Pulsin returns the correct value for the incoming pulse !!!
    Dec 2003
    Wichita KS
    Hello Ace,
    Did you try that While and endwhile code I gave you???
    What that code is doing, is ridding you of a "Burp" jump out of a "IF" statement.
    Take a look at that while /endwhile code I posted.
    Dwayne
    Ability to Fly:
    Hi, Dwayne
    I'll try that this week-End ... on the Breadboard, Electronics is not my job !!!
    What feds me up is that ALL the IF THEN tests I place after this part of code( wich crosses the 2K limit ...) have a YES answer ... whatever the test does.
    I'll try to confirm with a " IF 1 = 0 THEN ..." ... we'll see then.
    I'll also try to move my subs at the real END of the program ( I have a GOTO - GOTO part added after the subs ) REMEMBER it runs like that on a 16F628 ....
    AND everything has END separators not to punch through.
    IF you want the source ... it's the R/C magic box !!! ( parallelling and trimming center and half travel for two servos driven by one channel )
  1. Worst day of my life
    By brid0030 in forum USB
    Last Post: - 12th March 2008, 22:27
  2. EEPROM life expectancy?
    By muddy0409 in forum General
    Last Post: - 1st May 2007, 12:44
  3. Replies: 5
    Last Post: - 11th February 2007, 23:55
  4. Any chance of Life being easy?
    By josegamez in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2006, 20:52
  5. above 2k with 16F877
    By Peter Oors in forum mel PIC BASIC Pro
    Last Post: - 6th March 2006, 12:43
