PWM GENERATION OF 25nS - 70nS outputs
Results 1 to 25 of 25
    Sep 2009
    Default Re: PWM GENERATION OF 25nS - 70nS outputs
    That is more RF circuitry than digital...
    To get square wave at that speed you are talking about frequency components of tens of MHz, at least... You must use transmission lines, matched source and load to get it working.
    And that isn't PWM because you have fixed off time. So it's variable frequency with constant off time. You can check out constant on time DC/DC for ideas, just invert output.
    If I was doing that, I'll try create something like NE555 with LTC1394, fixed OFF time, and adjustable current source for charging on time capacitor...
    You can find some ideas in Linear AN94 for delay circuit.
    So use pic just to adjust charging current.
    EDIT:
    Just replace R1 with variable constant current
    http://www.electronics-tutorials.ws/waveforms/tim47.gif
    And build NE555 on steroids...
    Then ON time depending linearly on C and current. Off depending on R2 and C.
  1. Sinusoidal PWM generation Using PIC 18f4431
    By oswalam in forum mel PIC BASIC
    Last Post: - 23rd February 2013, 16:49
  2. 4 x PWM outputs
    By Scampy in forum mel PIC BASIC Pro
    Last Post: - 7th February 2012, 07:40
  3. Generation of PWM wave six - PIC18f4431
    By Salatiel_lobato in forum mel PIC BASIC Pro
    Last Post: - 25th March 2011, 20:37
  4. PWM generation with PIC16F628
    By Marin in forum mel PIC BASIC Pro
    Last Post: - 16th July 2010, 10:50
  5. sine pwm generation using pic16f72
    By kvrajasekar in forum mel PIC BASIC Pro
    Last Post: - 13th October 2008, 10:02
