PIC 18f2550 USB joystick TROUBLE (burnt PIC?)
Results 1 to 5 of 5
    Default PIC 18f2550 USB joystick TROUBLE (burnt PIC?)
    hello everyone, i finished my 2 axis and 7 button joystick, plugged it into my PC and checked the device manager and everything was working OK
    then i unplugged the device and went on with my life....
    later, idecided to check my device again and plugged it back into the PC, "unknown Device" showed up on the device manager, i uninstalled the controler for this "unknown Device" and unplugged and plugged back in and i still get unknown device from the device manager.
    i was wondering if there is something that went wrong with my coding or with my circuit (maybe i burnt my PIC for some reason) i will attach my code and my schematic for reference.
    maybe i did something wrong, please advice me. this would be greatly appreciated
    Schemmatic;
    ignore the LEDS on the diagram (i did not place those there) and C3 is 330nf instead of 470nf
    on the outputs you see in the CODE i used an LED connected to a 4kohm resistor an then to GND
    i also connected POTS of 2khoms to AN0 and AN1 (RA0 and RA1)
    CODE:
    ' * Auto generated EasyHID file. PBP 2.60 and above *
    ' include the HID descriptor
    include "DESCEGGJOY.bas"
    DEFINE OSC 48
    DEFINE LOADER_USED 1
    USBBufferSizeMax con 3 ' maximum buffer size
    USBBufferSizeTX con 3 ' input
    Define ADC_BITS 8 ' Set number of bits in result
    Define ADC_SAMPLEUS 100 ' Set sampling time in uS
    ' the USB buffer...
    USBBuffer Var Byte[USBBufferSizeMax]
    USBBufferCount Var Byte
    ' Define ADCIN parameters
    PORTB = 0 'clear ports
    PORTA = 0
    PORTC = 0
    TRISC = 000000 'all are outputs
    TRISA = 010011 'ra0/1/4 are inputs
    TRISB = 111111 'rb0-5 are outputs
    ADCON1 = 001101 'AN0 and AN1 are inputs (RA0 and RA1)
    ' * main program loop - remember, you must keep the USB *
    ' * connection alive with a call to USBService every couple *
    ' * of milliseconds or so... *
    usbinit ' initialise USB...
    ProgramStart:
    ADCIN 0,USBBuffer[0]
    ADCIN 1,USBBuffer[1]
    USBBuffer.0(16) = porta.4
    portc.0 = porta.4
    USBBuffer.0(17) = porta.1
    portc.1 = portb.1
    USBBuffer.0(18) = portb.2
    portc.2 = portb.2
    USBBuffer.0(19) = portb.3
    portc.6 = portb.3
    USBBuffer.0(20) = portb.4
    portc.7 = portb.4
    USBBuffer.0(21) = portb.5
    USBBuffer.0(22) = portb.6
    gosub DoUSBOut
    goto ProgramStart
    ' * wait for USB interface to attach *
    DoUSBOut:
    USBBufferCount = USBBufferSizeTX ' TX buffer size
    USBService ' keep connection alive
    USBOut 1, USBBuffer, USBBufferCount, DoUSBOut ' if bus available, transmit data
    DESCRIPTOR:
    ' USB descriptors for a HID device
    'USBMEMORYADDRESS Con $400 ' USB RAM starts here (set in device header file)
    USBMEMORYSIZE Con 256 ' USB RAM size in bytes
    USBReservedMemory Var Byte[USBMEMORYSIZE] USBMEMORYADDRESS ' Reserve memory used by USB assembler code
    goto hid_desc_end ' Skip over all of the USB assembler code
    asm
    #define USB_EP0_BUFF_SIZE 64 ; 8, 16, 32, or 64
    #define USB_MAX_NUM_INT 1 ; For tracking Alternate Setting
    #define USB_MAX_EP_NUMBER 1 ; UEP1
    #define NUM_CONFIGURATIONS 1
    #define NUM_INTERFACES 1
    #define UCFG_VAL USB_PULLUP_ENABLE|USB_INTERNAL_TRANSCEIVER|USB_FUL L_SPEED|USB_PING_PONG__NO_PING_PONG
    ;#define UCFG_VAL USB_PULLUP_ENABLE|USB_INTERNAL_TRANSCEIVER|USB_LOW _SPEED|USB_PING_PONG__NO_PING_PONG
    ;#define USE_SELF_POWER_SENSE_IO
    ;#define USE_USB_BUS_SENSE_IO
    #define USB_POLLING
    ; HID
    ; Endpoints Allocation
    #define HID_INTF_ID 0x00
    #define HID_EP 1
    #define HID_INT_OUT_EP_SIZE 64
    #define HID_INT_IN_EP_SIZE 64
    #define HID_NUM_OF_DSC 1
    include "usb_hid.asm" ; Include rest of USB files, starting with HID class code
    ; This table is polled by the host immediately after USB Reset has been released.
    ; This table defines the maximum packet size EP0 can take.
    ; See section 9.6.1 of the Rev 1.0 USB specification.
    ; These fields are application DEPENDENT. Modify these to meet
    ; your specifications.
    DeviceDescriptor
    retlw (EndDeviceDescriptor-DeviceDescriptor)/2 ; bLength Length of this descriptor
    retlw USB_DESCRIPTOR_DEVICE ; bDescType This is a DEVICE descriptor
    retlw 0x10 ; bcdUSBUSB Revision 1.10 (low byte)
    retlw 0x01 ; high byte
    retlw 0x00 ; bDeviceClass zero means each interface operates independently
    retlw 0x00 ; bDeviceSubClass
    retlw 0x00 ; bDeviceProtocol
    retlw USB_EP0_BUFF_SIZE ; bMaxPacketSize for EP0
    ; idVendor (low byte, high byte)
    retlw 0x81
    retlw 0x17
    ; idProduct (low byte, high byte)
    retlw 0xD8
    retlw 0x07
    retlw 0x00 ; bcdDevice (low byte)
    retlw 0x00 ; (high byte)
    retlw 0x01 ; iManufacturer (string index)
    retlw 0x02 ; iProduct (string index)
    ; iSerialNumber (string index)
    retlw 0x03
    retlw NUM_CONFIGURATIONS ; bNumConfigurations
    EndDeviceDescriptor
    ; This table is retrieved by the host after the address has been set.
    ; This table defines the configurations available for the device.
    ; See section 9.6.2 of the Rev 1.0 USB specification (page 184).
    ; Modify these to meet your specifications.
    ; Configuration pointer table
    USB_CD_Ptr
    Configs
    db low Config1, high Config1
    db upper Config1, 0
    ; Configuration Descriptor
    Config1
    retlw (Interface1-Config1)/2 ; bLength Length of this descriptor
    retlw USB_DESCRIPTOR_CONFIGURATION ; bDescType 2=CONFIGURATION
    Config1Len
    retlw low ((EndConfig1 - Config1)/2) ; Length of this configuration
    retlw high ((EndConfig1 - Config1)/2)
    retlw 0x01 ; bNumInterfaces Number of interfaces
    retlw 0x01 ; bConfigValue Configuration Value
    retlw 0x00 ; iConfig (string index)
    retlw _DEFAULT|_SELF ; bmAttributes attributes - bus powered
    ; Max power consumption (2X mA)
    retlw 0x32
    Interface1
    retlw (HIDDescriptor1-Interface1)/2 ; length of descriptor
    retlw USB_DESCRIPTOR_INTERFACE
    retlw 0x00 ; number of interface, 0 based array
    retlw 0x00 ; alternate setting
    retlw 0x02 ; number of endpoints used in this interface
    retlw 0x03 ; interface class - assigned by the USB
    retlw 0x00 ; boot device
    retlw 0x00 ; interface protocol
    retlw 0x00 ; index to string descriptor that describes this interface
    HIDDescriptor1
    retlw (Endpoint1In-HIDDescriptor1)/2 ; descriptor size (9 bytes)
    retlw DSC_HID ; descriptor type (HID)
    retlw 0x11 ; HID class release number (1.11)
    retlw 0x01
    retlw 0x00 ; Localized country code (none)
    retlw 0x01 ; # of HID class descriptor to follow (1)
    retlw 0x22 ; Report descriptor type (HID)
    ReportDescriptor1Len
    retlw low ((EndReportDescriptor1-ReportDescriptor1)/2)
    retlw high ((EndReportDescriptor1-ReportDescriptor1)/2)
    Endpoint1In
    retlw (EndPoint1Out-Endpoint1In)/2 ; length of descriptor
    retlw USB_DESCRIPTOR_ENDPOINT
    retlw HID_EP|_EP_IN ; EP1, In
    retlw _INT ; Interrupt
    retlw low (HID_INT_IN_EP_SIZE) ; This should be the size of the endpoint buffer
    retlw high (HID_INT_IN_EP_SIZE)
    retlw 0x0A ; Polling interval
    EndPoint1Out
    retlw (EndConfig1-EndPoint1Out)/2 ; Length of this Endpoint Descriptor
    retlw USB_DESCRIPTOR_ENDPOINT ; bDescriptorType = 5 for Endpoint Descriptor
    retlw HID_EP|_EP_OUT ; Endpoint number & direction
    retlw _INT ; Transfer type supported by this Endpoint
    retlw low (HID_INT_OUT_EP_SIZE) ; This should be the size of the endpoint buffer
    retlw high (HID_INT_OUT_EP_SIZE)
    EndConfig1
    ReportDescriptor1
    retlw 0x05
    retlw 0x01 ; USAGE_PAGE (Generic Desktop)
    retlw 0x09
    retlw 0x04 ; USAGE (Joystick)
    retlw 0xa1
    retlw 0x01 ; COLLECTION (Application)
    retlw 0x09
    retlw 0xa1
    retlw 0x00 ; COLLECTION (Physical)
    retlw 0x09
    retlw 0x30 ; USAGE (X)
    retlw 0x09
    retlw 0x31 ; USAGE (Y)
    retlw 0x75
    retlw 0x08 ; REPORT_SIZE (8)
    retlw 0x95
    retlw 0x02 ; REPORT_COUNT (2)
    retlw 0x35
    retlw 0x00 ; PHYSICAL_MINIMUM (0)
    retlw 0x46
    retlw 0xff
    retlw 0x00 ; PHYSICAL_MAXIMUM (255)
    retlw 0x81
    retlw 0x03 ; INPUT (Cnst Var Abs)
    retlw 0x05
    retlw 0x09 ; USAGE_PAGE (Button)
    retlw 0x19
    retlw 0x01 ; USAGE_MINIMUM (Button 1)
    retlw 0x29
    retlw 0x07 ; USAGE_MAXIMUM (Button 7)
    retlw 0x15
    retlw 0x00 ; LOGICAL_MINIMUM (0)
    retlw 0x25
    retlw 0x01 ; LOGICAL_MAXIMUM (1)
    retlw 0x75
    retlw 0x01 ; REPORT_SIZE (1)
    retlw 0x95
    retlw 0x08 ; REPORT_COUNT (8)
    retlw 0x81
    retlw 0xc0 ; END_COLLECTION
    ; String pointer table
    USB_SD_Ptr
    Strings
    db low String0, high String0
    db upper String0, 0
    db low String1, high String1
    db upper String1, 0
    db low String2, high String2
    db upper String2, 0
    db low String3, high String3
    db upper String3, 0
    String0
    retlw (String1-String0)/2 ; Length of string
    retlw USB_DESCRIPTOR_STRING ; Descriptor type 3
    retlw 0x09 ; Language ID (as defined by MS 0x0409)
    retlw 0x04
    ; company name
    String1
    retlw (String2-String1)/2
    retlw 'e'
    retlw 0x00
    retlw 'g'
    retlw 0x00
    retlw 'g'
    retlw 0x00
    retlw 'j'
    retlw 0x00
    retlw 'o'
    retlw 0x00
    retlw 'y'
    retlw 0x00
    ; product name
    String2
    retlw (String3-String2)/2
    retlw 'e'
    retlw 0x00
    retlw 'g'
    retlw 0x00
    retlw 'g'
    retlw 0x00
    retlw 'j'
    retlw 0x00
    retlw 'o'
    retlw 0x00
    retlw 'y'
    retlw 0x00
    ; serial number
    String3
    retlw (String4-String3)/2
    retlw '0'
    retlw 0x00
    retlw '0'
    retlw 0x00
    retlw '0'
    retlw 0x00
    retlw '1'
    retlw 0x00
    String4
    endasm
    hid_desc_end
    Mar 2008
    Gerogetown, Texas
    Default Re: PIC 18f2550 USB joystick TROUBLE (burnt PIC?)
    I have made several joy stick projects over the years. A couple of observations.
    1. In your ReportDescriptor1, you have only allocated 7 bits (buttons 1 to 7) You either need to change to
    retlw	0x01		;	usage minimum  (button 1)
    	retlw	0x29
    	retlw	0x08		;	usage maximum  (button 8)
    	retlw	0x15
    	retlw	0x00		;	logical min (0)
    	retlw	0x25
    	retlw	0x01		;	logical max (1)
    	retlw	0x75
    	retlw	0x01		;	report size (1)
    	retlw	0x95
    	retlw	0x08		; 	report count (8)
    or add a one bit filler.
    I have always used 10K pot for analog inputs.
    Make sure you loop is less than 10ms or USB will time out.
    Hope this helps
    What happens if you reboot and try again?
    DAVE: i will try all of your solutions to my problem, but how do you explain that the device worked before and all of a sudden it doesnt?
    DEMON: i did that and still get "Unknown Device" even o other computers
    i will run to the store and buy a new PIC and see if thats what died on me (and maybe some new CAPS and POTS)
    Thanks for the help so far guys (lets keep it coming XD )
    SOLVED:
    Changed C3 from 330nf (ceramic capacitor) to 470nf (polyester capacitor) and worked like a charm, thanks for the input guys.
    i also changed my pots to 10k as you suggested, but i think ill revert to 2Kohm ones since there is less "noise" (jumping between values)
  1. Where To Get Started With ADC (Pic 18f2550 / 4550)
    By jsags1 in forum FAQ - Frequently Asked Questions
    Last Post: - 17th October 2014, 04:26
  2. USB HID Joystick for Dummies
    By Squibcakes in forum USB
    Last Post: - 2nd May 2014, 07:52
  3. Trade - Swap other PIC/s for single 18F2550
    By mr.sneezy in forum Adverts
    Last Post: - 25th February 2009, 07:44
  4. Need help PIC 18F2550 with DS 1302
    By christina86 in forum mel PIC BASIC
    Last Post: - 28th December 2007, 01:05
  5. USB joystick project
    By ZeroFusion in forum USB
    Last Post: - 18th November 2006, 18:21
