Use a switch by change not on/off status.
Results 1 to 17 of 17
Threaded View
  1. #15
    Default Re: Use a switch by change not on/off status.
    Ok, a JK FlipFlop is a 2 input one output device.
    I am guessing you are using a latching relay which
    changes states every time it is energised, is
    this correct?
    If so you need to read 2 pins to check switch state.
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _CP_OFF
    TrisA = %00000011
    TRISC = %00000000
    PortC = %00000000
    ANSEL=0
    ANSELH=0
    ADCON0 = 0
    ADCON1 = 0
    Option_Reg = %00000000 ; enable RABPU
    WPUA = %00000011  ;Set RABPU
    If PortA.0 = 0 then
    portc.2 = 1
    pause 500  ; 1/2 seconds of power out
    portc.2 = 0
    goto Impatient  ; wait for microswitch to zero
    Impatient:
    while PortA.1 = 1
    portc.3 = 1
    portc.3 = 0
    wend
    if PortA.1 = 0 then goto main
    Tested with 16F690 demo board. Weak pullups did not work, had to use real resistors, likely because the PICKit2 was still connected. LEDs were enabled to verify operation
  1. Toggle switch (latching switch) state
    By craigwb in forum General
    Last Post: - 6th November 2011, 15:18
  2. Switch sensor vs. switch PIC pin
    By fratello in forum Schematics
    Last Post: - 4th August 2011, 12:17
  3. Interrupt status?
    By circuitpro in forum mel PIC BASIC Pro
    Last Post: - 28th February 2011, 02:27
  4. Replies: 6
    Last Post: - 9th January 2011, 16:26
