TI CC1101 Radio Project
Results 1 to 23 of 23
    Default Re: TI CC1101 Radio Project
    I have successfully used the RSSI from a receiver for TPM testing at work while designing an AGC circuit for a TPM Transmitter program. just remember that if using ASK transmissions you will need a fast A/D and you should gather enough data during a xmission to see the PEAK level. I have used this to program an 8 bit attenuator at the frontend of the receiver using successive approximation routine I wrote. That way each of the test Transmitters have the same received signal strength to the receiver for timing verification purposes. It is NOT as critical for the A/D if you are using FSK mode. I wish I could share more but I wrote the software for the company I work for... Good Luck...
    EN82fn
    Nov 2007
    West Covina, CA
    You're welcome Steve,
    Yup, that's one of them. I also used the other where you have to connect an external antenna.
    The device has a digital RSSI register that can be read continuously. I never got to it in that last product where I was going to use for "clear channel search".
    The code provided sets the transmitter modulation to 4 level FSK at +-39KHz deviation if I recall.
    It can be configured to be a transmitter only, receiver only or switch between the two modes, it's up to you.
    Your application is feasible, keeping air time management in mind to avoid transmission collisions, just like you would anyways with direct data connections.
    Here's 1 data sheet on the RSSI you can go through. I couldn't upload the other because of it's size but can get it here.
    Dave- What is TPM?
    Louie
    Sep 2007
    Waco, Texas
    thanks Guys-
    My modules are due in tomorrow, however, I have to go out of town on business so it will have to wait a bit longer darn it.
    I really can't wait to see this work!
    The MRF module never did work nor could I find ANYONE who saif they got it to work in packets!
    Thanks again. Will keep you posted on progress - and code.
    Regards to All.
    "If we knew what we were doing, it wouldn't be called research"
    - Albert Einstein
    Nov 2007
    West Covina, CA
    Yeah, I bought a pair of them MRF's too but only ended up staring at them cuz they look cool.
    Louie
    Sep 2007
    Waco, Texas
    Yup. I should have my radios in waiting for me Monday. Then I can see about playing with them.......
    - Albert Einstein
    Nov 2007
    West Covina, CA
    Steve,
    I remembered unsuccessfully trying to solder rework wire to the module's pads only to damage it.
    Do you make your PCBs?
    I have some older revision PCBs with footprints for these module if you're interested. No strings, just willing to help.
    Louie
    Sep 2007
    Waco, Texas
    I would REALLY appreciate that. I just looked at my radio development 'kits' (2) and all I got was the module with an antenna! It looks as if these plug into something else........
    So, it looks like I am going to make a cheap proto pcb....... I use Eagle, what do you use?
    - Albert Einstein
  1. Need Help with Radio Project
    By prstein in forum Off Topic
    Last Post: - 25th February 2011, 06:04
  2. Car radio (Car radio and electronics support forum)
    By freewillover in forum Forum Requests
    Last Post: - 1st July 2009, 20:41
  3. RS232 by Radio
    By Bill Legge in forum Serial
    Last Post: - 5th March 2009, 16:16
  4. radio pic connection
    By taos in forum General
    Last Post: - 25th February 2006, 01:55
  5. Help With Easy Radio Modules
    By hughgoodbody in forum General
    Last Post: - 25th May 2005, 10:14
