Bloody F886
Results 1 to 10 of 10
Thread: Bloody F886
    Jun 2005
    Up the bush, Western Plains, NSW Au
    Default Bloody F886
    I am having a devil of a time getting the config working on a F886.
    PBP 2.60 & MPASM
    @ __config _CONFIG1, _HS_OSC & _WDT_OFF & _MCLRE_OFF & _LVP_OFF & _CP_OFF
    @ __config _CONFIG2, _WRT_OFF
    That is my entire program ATM
    When I Compile I get
    overwriting previous address contents (2007)
    If I REM out second line only, same thing
    If I REM out first line only, compiles OK
    So I figure there is something wrong in config1 stuff. These 2 lines were directly coppied from elsewhere in this forum and pasted.
    WTF is going on here.
    I'm getting too damn old for this crap.
    BTW is there anywhere I can see what the individual config bits actually mean. I have seen the bottom of the .INC file, that names the words contents but not the bit positions.
    Would be great to see something like
    CONFIG1.0 IS WDT 1=ON 0=OFF
    CONFIG1.2 IS MCLRE 1=ON 0=OFF
    or whatever they are.
    Time for an OUZO and COKE I think. (or 2 or 3)
    Thank you in advance as always.
    Peter Moritz.
    New South Wales,
    Australia.
    Default Re: Bloody F886
    Hi Peter,
    I think you will find instructions here: http://www.picbasic.co.uk/forum/showthread.php?t=543
    In 2.6 you still have to comment the configs in the xxx.inc files
    depending on your level of patience
    or just edit the pic16f886.inc file to suit.
    too slow
    Jun 2005
    Have investigated a full day without success.
    Next suggestion..
    Does anyone have a WORKING F886 program, in PBP 2.60, with MPASM, (onWin7 PRO 64 bit on a laptop) that does work? that they could show me (at least the WORKING configs and DEFINES sections ) and let me copy into my setup just to let me see that my setup is OK and compiling successfully.
    Otherwise, I am feeling I will migrate over to Great Cow ans see if that does everything? Much as I would prefer to stay with the MEL stuf 'cos I do normally know enough to bluff my way through. FYI I am using the CHIPINO board for some projects, or at least I will if I can get my setup going.
    Peter Moritz.
    New South Wales,
    Australia.
    in your pbp dir you have a file called 16f886.inc
    edit it to look like this below
    remove all config statements from your pgm
    failing that upgrade to pbp3 it makes life much easier
    silver edition is only $25 at dontronics if the have any left
    ;* 16F886.INC *
    ;* By : Leonard Zerman, Jeff Schmoyer *
    ;* Notice : Copyright (c) 2009 microEngineering Labs, Inc. *
    ;* All Rights Reserved *
    ;* Date : 07/02/09 *
    ;* Version : 2.60 *
    ;* Notes : *
    NOLIST
    ifdef PM_USED
    LIST
    include 'M16F88x.INC' ; PM header
    device pic16F886, intrc_osc_noclkout, wdt_on, mclr_on, lvp_off, protect_off
    XALL
    NOLIST
    LIST
    LIST p = 16F886, r = dec, w = -302
    INCLUDE "P16F886.INC" ; MPASM Header
    __config _CONFIG1, _HS_OSC & _WDT_ON & _MCLRE_OFF & _LVP_OFF & _CP_OFF
    NOLIST
    LIST
    Jun 2005
    OK Rich, did that
    Wrote a simple 2 line prg...nothing but these 2 lines...
    define osc 16
    PORTC = 0
    When I compile, get lots of errors.....
    ERROR [113] PBPPIC14.LIB SYMBOL NOT PREVIOUSLY DEFINED (PORTC)
    WTF?????
    Peter Moritz.
    New South Wales,
    Australia.
    Hi Peter,
    First, are you sure you have the correct device (PIC18F886) selected in the dropdown list in MicroCodeStudio?
    Second, not related to the error message, define is a case sensitive statement. osc and OSC are not the same thing. For PBP to correctly pick up that you intened to run at 16MHz you need to define OSC 16.
    Jun 2005
    Rightio.
    Changed the osc to OSC
    Now it compiles but with the following...
    but at least it is compiling and programming...but when I read the chip back, the config bits have not changed....melabs usb programmer.
    looks like it doesn't like the .inc file that was changed?
    Peter Moritz.
    New South Wales,
    Australia.
    sorry the forum eats up all the white space
    use the attachment but rename it to 16f886.inc
    Jun 2005
    Hmmm...
    yep, that looks like it goes with no problems now, with a small correction to the HS_OSC part.
    Thanks SO much.
    You can have the rest of the weekend off...
    Peter Moritz.
    New South Wales,
    Australia.
  1. F886 & pgm
    By MOUNTAIN747 in forum General
    Last Post: - 9th February 2010, 22:19
