Turn off analog comparators so your pins can be used for digital I/O.
CMCON = 7
PULSOUT toggles the pin twice, so the initial state of the pin determines
the logic of the pulse.
LOW 0 ' We want a high-going pulse or low-high-low with pulsout.
You may want to tweak the pulsout periods, but that should get you started.Code:@ DEVICE MCLR_OFF,INTRC_OSC,WDT_OFF,PROTECT_OFF Define OSCCAL_1K 1 ' Load factory value into OSCCAL CMCON = 7 ' Turn analog comparators off X VAR BYTE LOW 0 ' Setup GPIO,0 to output a high-going pulse with pulsout Main: FOR X = 1 to 50 pulsout 0, 100 pause 15 NEXT X pause 1000 FOR X = 1 to 50 pulsout 0, 200 pause 15 NEXT X pause 1000 goto Main end
Make sure you use a separate power supply for your servo. Using the same PS as the PIC will cause problems.
