Compiling using PBP mode causes funnies
Results 1 to 10 of 10
    Apr 2011
    Kent, UK
    Default Re: Compiling using PBP mode causes funnies
    Hi Henrik,
    Yes identical hardware, it just looks like PBP runs faster than PBPL!
    Tim.
    Hi Tim,
    Identical but not the same board?
    I'm asking because I guess it is possible that one board isn't running at the correct speed....wrong x-tal populated for example.
    PBP wil run faster than PBPL since the math routines will be 16 bit instead of 32 bit (doesn't matter if you're actually using LONGs or not). So if you're relying on a specific routine taking x amount of time then you can see a difference (depending on what the routine in question is doing) but if your using PAUSE or PAUSEUS there shouldn't be any difference at all.
  1. Replies: 2
    Last Post: - 19th June 2012, 22:24
  2. MikroBasic to PBP Pro: Boost mode SMPS
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 25th November 2011, 03:27
  3. I need HELP with compiling!!!!!!
    By kenny_m in forum mel PIC BASIC Pro
    Last Post: - 15th February 2008, 21:34
  4. Compiling problems
    Last Post: - 7th June 2005, 01:58
  5. Sleep Mode in PBP
    By Keith in forum mel PIC BASIC Pro
    Last Post: - 4th March 2005, 21:58
