I'm glad you've been able to narrow it down a Little bit but as far as I'm concerned that's almost equally weird - as long as it's a hardcoded pause of course and not using a variable for the duration (which would still be weird but perhaps not as much). Are you running this on the same board (not two different but "equal" boards) with the same clock speed and everything, the only change you make is to switch compiler between PBPW and PBPL?
Anyway, if you want further help you're going to have to come up with more details and/or show the offending code.
