Problems with DT interrupts (PT_INT interrupt)
Results 1 to 9 of 9
    Default Re: Problems with DT interrupts (PT_INT interrupt)
    When you tell DT-INTS to clear the flag (by setting the reset flag option to YES) you don't need to clear it manually in the ISR. If you set the option to NO then DT-INTS will leave the flag alone and its up to you (or the hardware) to handle it the flag as needed.
    Thanks Henrik
    I will let the DT-INTS clear the flag, I think it's more "efficient" than clear the flag manually...
    Question Re: Problems with DT interrupts (PT_INT interrupt)
    Nevermind...
    Jan 2012
    Grid EN19MV
    Nevermind...
    I'm glad someone else feels the same way I do when I try to answer things!
    -Stephen Hawking
    I had quoted Pedja thinking I had selected the OP and saw nothing wrong with the Main routine.
  1. Replies: 5
    Last Post: - 3rd August 2014, 11:36
  2. Interrupt problems!
    By amindzo in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2006, 15:55
  3. Replies: 1
    Last Post: - 1st November 2006, 04:11
  4. RB0 interrupt problems
    By amindzo in forum General
    Last Post: - 26th August 2006, 12:52
  5. Problems with 16F876 on interrupts an WRITE / READ
    By BigWumpus in forum mel PIC BASIC Pro
    Last Post: - 20th December 2005, 15:38
