Very quick question... To help a dim wit !!
Results 1 to 5 of 5
    May 2012
    Merseyside, UK
    Default Re: Very quick question... To help a dim wit !!
    Hi...
    But what would the right "if-then" would be for this ??
    Sorry.... Just seen it in the code tags
    Thank you... Makes sense now !
    BR
    Andy
    Quote Originally Posted by andybarrett1 View Post
    Hi...
    Andy
    Hi Andy,
    The "right" one is the one that works for YOU the person doing the programming. Many options exist. If Then is a Boolean or true false expression. You could use select case, or branch, on goto to acheive the same results.
    May 2012
    Merseyside, UK
    Hi
    I was referring back to my first post…. I just missed the Syntax…! My Bad.
    Point is good and I have learned that very thing here time and time again….So much to learn so little time.
    Work gets in the way ….. But buys the chips…
    Thank you all for help !!
  1. Quick DTMFOUT Question
    By rocket_troy in forum General
    Last Post: - 8th July 2014, 06:57
  2. Quick PIC16F874A question
    By ERMEGM in forum mel PIC BASIC Pro
    Last Post: - 28th June 2014, 09:09
  3. A quick question.....
    Last Post: - 17th December 2010, 15:25
  4. Interrupt Quick Question
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 25th January 2005, 06:51
  5. quick question
    By Srigopal007 in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2004, 02:45
