Hello,
I'm implementing Space Vector PWM in PBP in order to control with variable speed an 3-phase AC motor.
The base of my work is the AN955 from Microchip.
http://ww1.microchip.com/downloads/e...tes/00955a.pdf
In order to modify the output frequency, you have to modify the speed of the rotating vector Vs. (page 3)
So a "Degree_constant" is pre-defined (in my case 39)
The "Required_motor_speed" is in my case 50
So the "Vector_update_step_size" is 39*50=1950
And "Vector_angle"="Vector_angle"+1950
This is explained in page 8.
But I don't really understand the source code provided, especially that "Carry" thing (in ASM) :
;ISR FOR VECTOR ROTATION AND PHASE PWM DUTY CYCLE UPDATE
ISR_PWM
BCF PIR3,PTIF ;CLEAR PWM TIMER INTERUPT FLAG
BTFSS ACSVM_FLAGS_1,FWD_REV
BRA FIND_VECTOR_ANGLE_FOR_REV_DIR
MOVFF PARAMETER_BUFFER+LOC_UPDATE_STEP_LSB,WREG ;INCREMENT VECTOR BY UPDATE STEP SIZE
ADDWF VECTOR_ANGLE_LSB,F
MOVFF PARAMETER_BUFFER+LOC_UPDATE_STEP_MSB,WREG
ADDWFC VECTOR_ANGLE_MSB,F
BNC READ_TIME_TB_COUNT ;DUE TO VECTOR INCREMENT, FOR CARRY = 0, CALCULATE CORRESPONDING TIME VALUES
INCF SECTOR_NO,F ;DUE TO VECTOR INCREMENT, FOR CARRY = 1, INCREMENT SECTOR NO
BRA CHECK_SECTOR_OF
SUBWF VECTOR_ANGLE_LSB,F
SUBWFB VECTOR_ANGLE_MSB,F
BC READ_TIME_TB_COUNT
INCF SECTOR_NO,F
CHECK_SECTOR_OF
MOVLW 0X05
CPFSGT SECTOR_NO
BRA READ_TIME_TB_COUNT
CLRF SECTOR_NO ;FOR SECTOR NO. ROLL OVER, REINITIALIZE SECTOR NO. TO 0
READ_TIME_TB_COUNT
Can anyone would translate this ASM part of code in something more "PBPish"?
