20MHz crystal
Results 1 to 9 of 9
Thread: 20MHz crystal
    markdem's Avatar
    markdem Guest
    Default 20MHz crystal
    Hi All. I am trying to build a very simple device with a PIC16F877A, but i can make the 20MHz crystal start. After about 2 hours of playing with it, i can make it work by touching the OCS2 pin with my hand. It will not work if i ground it. I can touch it before or after the crystal. It is almost like i am adding to the storage of the caps. I have tried all cap values from 10pf to 33pf, but it does not help. I have surched this forum and the web, but can not work this one out.
    I have set the HS fuse, have tried new crystals, caps etc and have put a 1M risistor across the osc1 and osc2 pins. What else can i try??
    Thank you for your help
    Mark
    markdem's Avatar
    markdem Guest
    Just to add to the problem, i have now tried a 4MHz resonator, and changed my code to reflect (XT and speed) but i still have the same problem. Any ideas??
    Thanks, Mark
    Hmmm... you got your MCLR pin floating?
    ensure... You have pin 1 (MCLR) connected to +5v
    ensure you have +5v on the Vdd pin
    ensure you have BOTH Vss pins connected to 0v
    Burn-in a blink LED program (with the LED on a PortB pin so as not to worry about internal ADC's and comparators) to test your PIC is alive.
    Last of all, try another PIC.
    Dec 2003
    Wichita KS
    I think Mel's hit it right on the head....
    The MClR pin.....
    Make sure you are not programming your chip with the MCLR pin as a reset. Make it a "input"... and/or tie it to 5 volts.
    Dwayne
    PS: One other thing... If you don't use switches to toggle the flags on your programmer, the MCLR seems to default to "reset"... Thus you changing it to "input pin" will be nullified when you attempt to program your chip a second time. I have been caught with my pants down a few times on this <g>... This I use Switches in my program now, for setting the Melabs programmer to the proper configuration.
    Ability to Fly:
    Hurling yourself towards the ground, and missing.
    Engineers that Contribute to flying:
    Both optimists and pessimists contribute to the society. The optimist invents the aeroplane, the pessimist the parachute
    Pilots that are Flying:
    Those who know their limitations, and respect the green side of the grass...
    Can also be a damn breadboard loose or faulty contact.
    What about if you remove both capacitor around the crystal???
    markdem's Avatar
    markdem Guest
    Hi all, thank you so much for helping me. I dont know what i am doing wrong. I have now got a new PIC (PIC16F84A) and it will stilll do the same thing. I have checked the connections, and all are OK. I have tried to remove the charge caps, but it does not help. I have checked the MCLR, and it does have +5 on it. The only way i can make anything work here is by touching OSC1 with my bare hand, like i am giving it ground or somting. Sorry, i am not too good at this, and still only learning. What else can i try?
    Thank you
    Mark
  1. Sharing Crystal with 2 IC's
    By ShaneMichael in forum mel PIC BASIC Pro
    Last Post: - 10th January 2013, 14:33
  2. 20 Mhz Crystal, simple blinking LED
    By BenjaminsShinob in forum mel PIC BASIC Pro
    Last Post: - 16th October 2007, 06:06
  3. 20MHz improve RF over 16F628A?
    By mbw123 in forum mel PIC BASIC Pro
    Last Post: - 28th November 2006, 17:04
  4. 20Mhz crystal cause led to blink irreguarly
    By niknaksbarbeque in forum mel PIC BASIC Pro
    Last Post: - 16th April 2005, 12:35
  5. 20Mhz Crystal /Resonators
    By mslaney in forum Schematics
    Last Post: - 5th January 2005, 15:49
