Hall-effect Switches and pic Inputs
Results 1 to 5 of 5
    May 2012
    Merseyside, UK
    Default Hall-effect Switches and pic Inputs
    Hi...
    Has any body had experience in using hall-effect switches with Pics.
    Are there any design considerations it would be good to be aware off.... I know most switches have Hyst. circuits built in (Allegro A1104) but are there any other rules.
    Both hardware and Software advice thank you.
    Thanks for reading
    Andy
    Default Re: Hall-effect Switches and pic Inputs
    I try to use only open collector to ground output devices with an on board pullup resistor so as not to chance injecting any high voltage spikes on any pins. Hall Efect Switches are much better than mechanical ones as there is no contact bounce. Watch for the ones that source or have PNP outputs as the source of there voltage is the source of there supply. If placed a resonable distance from the PIC input pin lines become great antennas. Most all of my designs however use opto isolators for digital input to elimnate these problems. Even with Hall Efect Switches.
    EN82fn
    the a1104 is a unipole device
    where the TLE 4913 is omnipole
    if N/S pole detection is wanted
    as dave said open collector/drain is the go
    there is always the ubiquitous UGN3503LT if you want to read analogue mag field strengths too
    May 2012
    Merseyside, UK
    Just ordered a free bunch from Allegro
    Will let you know how I get on.
    Thank you for advice....Open Drain Mosfets !!!
  1. Hall Effect flow meter with 16F876
    By revelator in forum mel PIC BASIC Pro
    Last Post: - 10th March 2010, 20:42
  2. Replacing Hall Effect throttle with PIC
    By idtat in forum General
    Last Post: - 22nd October 2009, 21:55
  3. Hall effect reading
    By ewandeur in forum mel PIC BASIC Pro
    Last Post: - 26th November 2008, 15:49
  4. Controlling switches with a PIC
    By TonyA in forum mel PIC BASIC Pro
    Last Post: - 4th March 2008, 22:44
  5. hall effect
    By dragons_fire in forum mel PIC BASIC Pro
    Last Post: - 10th April 2007, 15:49
