SWDTEN troubles (16F1933)
Results 1 to 7 of 7
    Default SWDTEN troubles (16F1933)
    am having troubles i can't track down, will buy a beer for anyone who can help
    PIC16F1933
    SWDTEN troubles
    my understanding is that if i set the configuration to SWDTEN then i can turn the WDT on and off w/ bit0 of WDTCON
    the programmer confirms i have "controlled by SWDTEN" in the config window
    setting to WDT ON or OFF in config works as expected with regard to NAP
    when WDT OFF in config
    NAP 18
    is sleep forever (i have IOC waking it up, works fine)
    when WDT is ON
    NAP 18
    sleeps for 256 seconds and then moves on to next code line
    both of the above are working great when i hard program WDT ON or OFF in config
    but now i really need to have it both ways, sometimes NAP forever until IOC, in another section i need NAP to proceed after a time
    so SWDTEN should be the ticket but i cannot get it to work
    no idea if it is PBP3 or the chip, at this point i don't think it is me unless there is something i don't understand that is keeping WDT ON
    it seems that i can turn WDT ON w/ WDTCON.0 = 1
    but subsequently i cannot turn it off again with WDTCON.0=0
    after WDTCON.0 = 0
    NAP 12
    just marches along after whatever time period 12 is (not long, i want it to sleep until IOC)
    any ideas what might be doing that ?
    by the way i can tell the bit is correct (0) it is just that WDT must be running anyway since NAP proceeds after the time
    does clock switchover setting have any role ?
    or Fail Safe Clock monitor (getting desperate as i have blown big time here)
    both of those are off
    Sep 2009
    Default Re: SWDTEN troubles (16F1933)
    If you look into .lst file you can find label called NAP.
    Here is copy/paste of code that deal with WDTCON
    movwf   FSR0H           ; Save period somewhere for a moment
    movlb   WDTCON >> 7     ; Point to bank
    movf    WDTCON, W       ; Save current WDTCON value
    movwf   FSR0L
    lslf    FSR0H, W        ; Get saved period and rotate it into position
    iorlw   1               ; Set software WDT on
    movwf   WDTCON          ; Set WDTCON
    sleep                   ; Enter sleep mode
    movf    FSR0L, W        ; Reset WDTCON to saved value
    movwf   WDTCON
    So every time you go to nap, PBP set SWDTEN, nap for while, and then restore value that was before going to nap.
    IF you_wait_for_IOC THEN
    WDTCON.0=0 'Disable WDT
    @ Sleep
    Else
    Nap 1
    movwf   FSR0L
    movwf   WDTCON
    @ Sleep
    Else
    Nap 1
    thank you!
    one thing (at least ) confuses me about your reply
    you say "PBP set SWDTEN"
    but that can only be done in CONFIG1, correct ?
    is your example compatible with 16F1933 or is it 18F ?
    here is from my LST file
    00C6 0085 06483 NAP movwf FSR0H ; Save period somewhere for a moment
    00C7 0021 06484 movlb WDTCON >> 7 ; Point to bank
    00C8 0817 06485 movf WDTCON, W ; Save current WDTCON value
    00C9 0084 06486 movwf FSR0L
    00CA 3505 06487 lslf FSR0H, W ; Get saved period and rotate it into position
    00CB 3801 06488 iorlw 1 ; Set software WDT on
    00CC 0097 06489 movwf WDTCON ; Set WDTCON
    00CD 0063 06490 sleep ; Enter sleep mode
    00CE 0804 06491 movf FSR0L, W ; Reset WDTCON to saved value
    00CF 0097 06492 movwf WDTCON
    00D0 2926 06493 goto DONE ; Done
    06514 LIST
    i will play with what i have learned here and back to you, thanks again
    Sep 2009
    SWDTEN is bit 0 of WDTCON register.
    When using nap iorlw 1 and movwf WDTCON enables SWDTEN bit before sleep.
    And WDTCON is restored after sleep.
    correct, SWDTEN is bit 0 of WDTCON, my usage of the term was not clear as SWDTEN is also the name one of the config settings for WDT, sorry about that
    the way i read everything in the data unless config1 <4:3> is set to allow SWDTEN then SWDTEN bit in WDTCON.0 is ignored
    this is from the data sheet for WDTCON
    WDTE is 2 bits in CONFIG1
    bit 0 SWDTEN: Software Enable/Disable for Watchdog Timer bit
    If WDTE<1:0> = 00:
    This bit is ignored.
    If WDTE<1:0> = 01:
    1 = WDT is turned on
    0 = WDT is turned off
    If WDTE<1:0> = 1x:
    this is what i cannot get to work correctly, have tried many things
    i can turn WDT hard ON or hard OFF in config and things work as expected, but when i set WDT to SWDTEN in config the SWDTEN bit of WDTCON does not work correctly,
    have tried setting it manually in parts of test code before and after NAP
    i can see the WDTCON.0 being of the expected state but WDT is not turning ON and OFF following the bit
    i think maybe NAP is not handling this chip correctly or maybe there is a bug in chip ?
    thanks for your patience in following up on this, maybe i have missed something you have said ?
    looking at the NAP ASM code it does not seem to know about the WDT config settings ? is that true ?
    Sep 2009
    It doesn't know... But relays on you to set WDT ON or to set WDT CONFIG to software control. If it is always on, then setting bit 0 doesn't have effect.
    If you set WDT to softvare control NAP will work as expected. It ALWAYS ENABLE WDT in WDTCON and wake up after while. If you disable WDT in CONFIG1, NAP stil enables bit 0 in WDTCON but it doesnt have effect. WDT will stay off and never wake up device.
    To wait for IOC, disable WDT in WDTCON, by reseting bit 0, and then use @ sleep to put device into low power mode.
    To wake up pic after while just use nap.
    I alredy wrote that at end of post #3.
  1. 12F1822 troubles
    By Charlie in forum mel PIC BASIC Pro
    Last Post: - 24th June 2012, 13:53
  2. "symbol not previously defined" on 16F1933 - fuse issue i think
    By comwarrior in forum mel PIC BASIC Pro
    Last Post: - 2nd January 2011, 04:24
  3. Issue using DATA statement with 16F1933 in PBP2.60
    By bcd in forum mel PIC BASIC Pro
    Last Post: - 10th August 2010, 02:36
  4. Troubles with I2C_Write
    By The Altruist in forum mel PIC BASIC Pro
    Last Post: - 24th March 2010, 00:57
  5. PIC16F676 Troubles
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 27th February 2005, 11:01
