Sending multiple serial strings.
Results 1 to 6 of 6
    Jul 2013
    Default Sending multiple serial strings.
    Hello,
    What is the best way to save and send multiple strings via serial?
    I need to send motion commands to a stepper motor controller. Each command (Stop, Left, Right, etc.) is comprised of (8) Hex codes. These are sent TTL 9600BPS, 8N1.
    My thought was to save each of these to a VAR (which could be a constant?) and then reference each when calling HSEROUT.
    ' Instead of directly:
    HESEROUT [HEX 55, AA, 1, FF, 0, 0, AA, 56]
    ' Use something like this:
    HESEROUT [mcuStop]
    Although directly works fine, it is quite awkward when creating elaborate motion profiles.
    I am not sure how to store these strings as VAR's/Array's/Tables or how to call them?
    Thanks!
    ' Partial list of about 24 commands.
    mcuStop = [HEX 55, AA, 1, FF, 0, 0, AA, 56]
    mcuCoast = [HEX 55, AA, 12, EE, 0, 0, AA, 56]
    mcuForward = [HEX 55, AA, 3, FD, 0, 0, AA, 56]
    mcuReverse = [HEX 55, AA, 4, FC, 0, 0, AA, 56]
    mcuLeft = [HEX 55, AA, 5, FB, 0, 0, AA, 56]
    mcuRight = [HEX 55, AA, 6, FA, 0, 0, AA, 56]
    mcuSpeed1 = [HEX 55, AA, 17, E9, 0, 0, AA, 56]
    mcuSpeed2 = [HEX 55, AA, 1A, E6, 0, 0, AA, 56]
    mcuSpeed3 = [HEX 55, AA, 18, E8, 0, 0, AA, 56]
    mcuSpeed4 = [HEX 55, AA, 19, E7, 0, 0, AA, 56]
    Default Re: Sending multiple serial strings.
    One way to do what you're asking for is something like
    mcuStop VAR BYTE[8]   ' Array of 8 bytes
      mcuStop[0] = $55
      mcuStop[1] = $AA
      mcuStop[2] = $01
      mcuStop[3] = $FF
      mcuStop[4] = $00
      mcuStop[5] = $00
      mcuStop[6] = $AA
      mcuStop[7] = $56
    HSEROUT [STR mcuStop]
    However, with 24 commands, each consisting of 8 bytes you're going to "waste" 152 bytes of RAM on this - which may or may not matter.
    Another aproach would be to create 24 subroutines and call them using GOSUB
    mcuStop:
      HESEROUT [$55, $AA, $01, $FF, $00, $00, $AA, $56]
    mcuCoast:
      HSEROUT [$55, $AA, $12, $EE, $00, $00, $AA, $56]
    GOSUB mcuStop
    GOSUB mcuCoast
    Yet another posibillity might be the user command feature in PBP3 but that's a quite advanced feature.
    It looks like all of the commands starts and ends with the same sequenct of bytes, 55, AA, xx, xx, 00, 00, AA, 56 where xx are the actual data. Is that valid for all commands?
    Jul 2013
    Option 1 is quite logical.
    Why does it "waste" RAM? Could it be stored in ROM instead?
    Option 2 is simple.
    In composing the moves, I do want to avoid typing those long strings over and over.
    Good observation.
    Each packet does have the same beginning and end. (55, AA and then AA, 56)
    The four bytes in between is the payload.
    Henrik is right. You can then tweak his approaches to use headers (prefix codes) and footers (suffix codes).
    Edit: "waste" is relative. It depends on your PIC, program size and variables used. If you have little codespace, option 1 might be better.
    If you "have" to use memory and you have little left on the PIC, is I/O time to external storage a concern?
    It all depends on your PIC, application requirements and personal preference.
    Waste may not have been the best word. What I mean is that the string for each command is static, they don't change, so there's no real need for them to live in RAM - which they'll do if you follow option 1 in my previous post. Again, there's nothing inherently wrong with this and it might be the easiest way if you have the RAM to spare.
    It IS stored in ROM (FLASH actually) when you do it like
    Which means that option 2 does, obviously, use less amount of RAM.
    With PBP3 there are ways to create unique usercommands but it's a pretty advanced topic. With the information given so far I'd go for option 2. Create a subroutine for each of the 24 commands and call them in sequence using GOSUB.
    EDIT: And if you DO go for option 2 and want to save some codespace you could probably do that by creating a "send header" and a "send footer" sub so you don't need to store the same 4 bytes for each command 24 times.
    mcuStop:
      GOSUB SendHeader : HESEROUT [$01, $FF, $00, $00] : GOSUB SendFooter
    SendHeader:
       HSEROUT [$55, $AA]
    SendFooter:
       HSEROUT [$AA, $56]
    EDIT2: And now, if you use an 18F part and have LONGs enabled you COULD possibly do something like:[code]
    Header CON $55AA
    Footer CON $AA56
    MotorStop CON $01FF0000
    mcuStop:
      GOSUB SendHeader : HESEROUT [MotorStop] : GOSUB SendFooter
    SendHeader:
       HSEROUT [Header]
    SendFooter:
       HSEROUT [Footer]
    Watch out for Little vs big endian, I'm not sure, off the top of my head how it's being sent here so you may need to reverse it.
    Jul 2013
    Yet another approach would be create mcuCMD array and just dynamically change interior bytes to a specific motion command.
    Boy, lots of options!
    Thanks for getting me started!
    For the immediate, I am going with Option 2 using the 24 GoSubs which is both pretty efficient and easy to read or maintain.
    Z
  1. Problem on sending data on serial port
    By bwaxing in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2011, 22:05
  2. Store and retrieve strings to an ATmel SPI Serial EEprom
    By BryanSw in forum mel PIC BASIC Pro
    Last Post: - 13th August 2010, 03:17
  3. Need help sending a hex serial output
    By cruzn27 in forum mel PIC BASIC Pro
    Last Post: - 5th December 2009, 14:24
  4. Parse Strings from (Assembly) Serial Interrupt
    By orlandoG in forum mel PIC BASIC Pro
    Last Post: - 10th April 2007, 17:17
  5. VB sending serial data to PIC
    By Tissy in forum Serial
    Last Post: - 8th March 2006, 19:31
