Pic18f2550 HID Keyboard
Results 1 to 21 of 21
    Jun 2007
    Default Pic18f2550 HID Keyboard
    Dears ,
    many Thanks For The Useful Info I Found Here To Achieve My Project , But Only I have One Concern i Cant Deal With It .
    i Can Connect The Pic To My Pc And Recognized , But When I Try To Send The below Character Or Any Other Character Its Repeated Forever I Don't Know Why .
    Bufferout[0] = 0
    Bufferout[1] = 0
    Bufferout[2] = $33
    Bufferout[3] = 0
    Bufferout[4] = 0
    Bufferout[5] = 0
    Bufferout[6] = 0
    Bufferout[7] = 0
    Output : ";;;;;;;;;;;;;;;;;;;;;;;;; . . . Forever"
    while :
    1st byte = modifier keys (i.e. ctrl, alt, shift)
    2nd byte = reserved
    3-8 = keys pressed ( 0x04 = a, 0x05 = b, ...)
    Default Re: Pic18f2550 HID Keyboard
    I don't see how someone can help with seeing all your code.
    Dec 2010
    You need to set the value, then send it, then clear it after it is sent once. Everytime you receive a poll, you will respond with whatever you have in the array. If your character is still there, you send it again.
    Jun 2007
    Dear Demon ,
    You Are Right , But Am In Work Now And i Cant Provide thE Full Code From Here , Anyway I Will Provide It ASAP ,And Thanks Again I Remember Last Time You Helped Me .
    Dear Charlie ,
    Can You Explain In Details Please , I Will Be Thanks If Code Is Provided , Many Thanks For Your Reply .
    Jun 2007
    Here Is My Code & USB Description attached .
    all i need is when i make portb pin 7 high then pic send char ";" .
    DEFINE OSC 48
    @ __CONFIG _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
    @ __CONFIG _CONFIG1H, _FOSC_HSPLL_HS_1H
    @ __CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_512_2H
    @ __CONFIG _CONFIG3H, _PBADEN_OFF_3H & _MCLRE_OFF_3H
    @ __CONFIG _CONFIG4L, _LVP_OFF_4L &_XINST_OFF_4L
    USBBufferSizeMax con 32 ' maximum buffer size
    USBBufferSizeTX con 32 ' input
    USBBufferSizeRX con 32 ' output
    ' the USB buffer...
    USBBuffer Var Byte[USBBufferSizeMax]
    USBBufferCount Var Byte
    ' * main program loop - remember, you must keep the USB *
    ' * connection alive with a call to USBService every couple *
    ' * of milliseconds or so... *
    usbinit ' initialise USB...
    ProgramStart:
    if portb.7 = 1 then
    USBBuffer[0] = 0
    USBBuffer[1] = 0
    USBBuffer[2] = $33 ; 33 = ";"
    USBBuffer[3] = 0
    USBBuffer[4] = 0
    USBBuffer[5] = 0
    USBBuffer[6] = 0
    USBBuffer[7] = 0
    gosub DoUSBIn
    gosub DoUSBOut
    goto ProgramStart
    ' * receive data from the USB bus *
    DoUSBIn:
    USBBufferCount = USBBufferSizeRX ' RX buffer size
    USBService ' keep connection alive
    USBIn 1, USBBuffer, USBBufferCount, DoUSBIn ' read data, if available
    ' * wait for USB interface to attach *
    DoUSBOut:
    USBBufferCount = USBBufferSizeTX ' TX buffer size
    USBOut 1, USBBuffer, USBBufferCount, DoUSBOut ' if bus available, transmit data
    if portb.7 = 1 then
    USBBuffer[0] = 0
    USBBuffer[1] = 0
    USBBuffer[3] = 0
    USBBuffer[4] = 0
    USBBuffer[5] = 0
    USBBuffer[6] = 0
    USBBuffer[7] = 0
    ....clear buffer...
    Just noticed something else, only send when you have to:
    if portb.7 = 1 then
    USBBuffer[0] = 0
    USBBuffer[1] = 0
    USBBuffer[3] = 0
    USBBuffer[4] = 0
    USBBuffer[5] = 0
    USBBuffer[6] = 0
    USBBuffer[7] = 0
    gosub DoUSBOut
    ....clear buffer...
    By the way, your buffer is 32 bytes long but you only use the first 8 bytes.
    Jun 2007
    I Told Them , Demon Is My Hero , I Will Try Today And Feedback , Many Thanks .
  1. USB HID is slower than often using PIC18f2550
    By Ahmadabuomar in forum mel PIC BASIC Pro
    Last Post: - 16th November 2010, 14:05
  2. HID Keyboard Example
    By apitaru in forum USB
    Last Post: - 6th August 2010, 16:27
  3. PIC18F2550 Newbie
    By JeffnDana in forum mel PIC BASIC Pro
    Last Post: - 26th April 2007, 15:13
  4. Replies: 3
    Last Post: - 18th January 2006, 14:12
  5. USB, PIC18F2550 and VB
    Last Post: - 27th November 2005, 18:37
