Creative ways to make macros with the least amount of code space
Results 1 to 5 of 5
    Default Re: Creative ways to make macros with the least amount of code space
    Using the TRIS register, simply state TRISx = %11111100 assuming you have already set the portx to %00000011 that would make outputs on. You would be switching between input and hot(logic 1) output. Why a macro?
    Nov 2007
    Maybe I didn't explain it right.
    Lets say you had a keypad with button 0 to 10. Each button press is read as a number under normal operation. Now put a big read button on the wall and allow that button to be custom programmed to be any button combination. So I could make that big red button on the wall bee 554422 or 541874, whatever I wanted. So you would put that button in to a "programming mode" and then on the keypad, type in the sequence you want, exit programming mode and now the big red button does that sequence every time you press it. It's like using a gaming keypad on a computer. You can record a macro or keystrokes that are replayed when pressing the button you chose to use to play the macro back (in our case the big red button).
    The only way I see to do this with little code space is getting creative with arrays but I have nearly zero experience with arrays.
    I'm a little weak with arrays too, but a keypad reader will require one. What you can do is have a subroutine with the master code and use the "big red button" control it. Mister_e did a keypad routine as an include, but you'll have to roll your own array to store the results.
    Jun 2009
    Sc*nthorpe, UK
    Quote Originally Posted by plyrathrt View Post
    Sound easy enough to me.
    Looks like a good reason to learn. Let me know if you want me to help.
  1. Working code but my layman approach uses too much code space
    Last Post: - 14th December 2012, 20:44
  2. I'm running out of code space example.
    Last Post: - 21st June 2010, 20:33
  3. Ways to make code easily reviewable and extendable
    By Ted's in forum mel PIC BASIC Pro
    Last Post: - 23rd August 2008, 00:10
  4. Need more code space
    By Sphere in forum General
    Last Post: - 19th September 2005, 20:49
  5. Need more code space
    By ghutchison in forum General
    Last Post: - 12th February 2005, 20:54
