Floating point math
Results 1 to 6 of 6
    Default Re: Floating point math
    Hey Art, Being you like to work with the 16F628's you might have a look at using one of the 16F1847's to replace it. 8K of flash, 1K of ram, 256 bytes of eeprom and 32Mhz. I have replaced a few 16F628's from old projects and they work a treet...
    EN82fn
    Aug 2003
    I did give a a lot of thought of getting it into one chip, and it would definitely be the dspic
    since I already have implemented the functions I want into another program for the same chip.
    This is just the first time I’ve had to do the hardware. The last one was a kit web server.
    Since I want the LCD to be continually driven, and am more apt with fancy graphics with an 8 bit pic,
    that’s the reason to consider the second chip.
    If I was happy with a fairly static LCD display, it would be easy with the dspic alone.
    The algorithms are Sunrise/set, Moonrise/Set, and Moon Illumination for a clock.
  1. Floating point math
    By Glenn in forum mel PIC BASIC Pro
    Last Post: - 5th January 2009, 04:47
  2. Getting out of floating point
    By jcb344 in forum General
    Last Post: - 5th August 2008, 22:18
  3. Replies: 5
    Last Post: - 28th May 2008, 11:20
  4. Floating Point
    By jrudd in forum mel PIC BASIC Pro
    Last Post: - 15th May 2005, 15:19
  5. help floating Point!
    By Eric in forum mel PIC BASIC Pro
    Last Post: - 7th December 2003, 22:18
