Help with Pic-18F23K22
Results 1 to 16 of 16
    Default Re: Help with Pic-18F23K22
    if you going to run it a 4mhz
    then
    CONFIG FOSC = INTIO67 instead of CONFIG FOSC = HSMP
    and
    OSCCON =$50
    and
    MainLoop:
    HIGH LED1
    PAUSE 500
    LOW LED1
    PAUSE 500 as dave said
    Goto Mainloop
    Sep 2014
    then
    and
    OSCCON =$50
    and
    MainLoop:
    HIGH LED1
    PAUSE 500
    LOW LED1
    Goto Mainloop
    Thank for reply Richard ,
    You are right , i used the default configuration and the led blink now , but as you can see this is a simple example. I want to use an external Xtal osc at 20 Mhz and from this point tried read the datasheet again for get the device working with external Xtal and frequency that i need .
    Thanks a lot ,
    Alex
  1. HSERIN2 Problem on 18F23k22
    By ethobias in forum Serial
    Last Post: - 26th May 2011, 00:48
  2. High Speed Serial Comm PC - PIC and PIC - PIC
    By manumenzella in forum mel PIC BASIC Pro
    Last Post: - 16th January 2007, 22:55
