Help with Pic-18F23K22
Results 1 to 16 of 16
    Sep 2014
    Default Help with Pic-18F23K22
    Hi ,
    I want to use 18F23K22 device in my proyect , after a lot of time reading the datasheet and Melabs configurator can't get blink a simple led with this device, maybe someone can give me help to find the mistake in my code.
    Here the code:
    CONFIG FOSC = HSMP ; HS oscillator (medium power 4-16 MHz)
    CONFIG PLLCFG = OFF ; Oscillator used directly
    CONFIG PRICLKEN = ON ; Primary clock enabled
    CONFIG FCMEN = OFF ; Fail-Safe Clock Monitor disabled
    CONFIG IESO = OFF ; Oscillator Switchover mode disabled
    CONFIG PWRTEN = OFF ; Power up timer disabled
    CONFIG BOREN = SBORDIS ; Brown-out Reset enabled in hardware only (SBOREN is disabled)
    CONFIG BORV = 190 ; VBOR set to 1.90 V nominal
    CONFIG WDTEN = OFF ; Watch dog timer is always disabled. SWDTEN has no effect.
    CONFIG WDTPS = 32768 ; 1:32768
    CONFIG CCP2MX = PORTC1 ; CCP2 input/output is multiplexed with RC1
    CONFIG PBADEN = OFF ; PORTB<5:0> pins are configured as digital I/O on Reset
    CONFIG CCP3MX = PORTB5 ; P3A/CCP3 input/output is multiplexed with RB5
    CONFIG HFOFST = ON ; HFINTOSC output and ready status are not delayed by the oscillator stable status
    CONFIG T3CMX = PORTC0 ; T3CKI is on RC0
    CONFIG P2BMX = PORTB5 ; P2B is on RB5
    CONFIG MCLRE = EXTMCLR ; MCLR pin enabled, RE3 input pin disabled
    CONFIG STVREN = ON ; Stack full/underflow will cause Reset
    CONFIG LVP = OFF ; Single-Supply ICSP disabled
    CONFIG XINST = OFF ; Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
    CONFIG DEBUG = OFF ; Disabled
    CONFIG CP0 = OFF ; Block 0 (000200-000FFFh) not code-protected
    CONFIG CP1 = OFF ; Block 1 (001000-001FFFh) not code-protected
    CONFIG CPB = OFF ; Boot block (000000-0001FFh) not code-protected
    CONFIG CPD = OFF ; Data EEPROM not code-protected
    CONFIG WRT0 = OFF ; Block 0 (000200-000FFFh) not write-protected
    CONFIG WRT1 = OFF ; Block 1 (001000-001FFFh) not write-protected
    CONFIG WRTC = OFF ; Configuration registers (300000-3000FFh) not write-protected
    CONFIG WRTB = OFF ; Boot Block (000000-0001FFh) not write-protected
    CONFIG WRTD = OFF ; Data EEPROM not write-protected
    CONFIG EBTR0 = OFF ; Block 0 (000200-000FFFh) not protected from table reads executed in other blocks
    CONFIG EBTR1 = OFF ; Block 1 (001000-001FFFh) not protected from table reads executed in other blocks
    CONFIG EBTRB = OFF
    OSCCON.0=0 'System Clock Primary Select Clock bit 0
    OSCCON.1=0 'System Clock Primary Select Clock bit 1
    CM1CON0.7=0 'Comparator 1 Off
    CM2CON0.7=0 'Comparator 2 Off
    ADCON0.0=0 'ADON:ADC Enable bit disabled
    ANSELA=%00000000 'PortA Digital
    ANSELB=%00000000 'PortB Digital
    ANSELC=%00000000 'Portc Digital
    INTCON=%00000000 'Disable All Interrupts
    INTCON2.7=1 'PortB Pull Up Disabled
    WPUB=%11000000 'Single PortB Pull Up PORTB0~PORTB7 enabled
    TRISA=%00000000 'PortA All Output
    TRISB=%00000000 'Portb All Output
    TRISC=%00000000 'PortC All Output
    LED1 VAR PORTC.0
    MainLoop:
    HIGH LED1
    PAUSE 500
    LOW LED1
    Goto Mainloop
    Feb 2012
    PERTH AUSTRALIA
    Default Re: Help with Pic-18F23K22
    try the pbp3.x standard profile for the chip as a start point to see what you get
    the file is found
    C:\Program Files (x86)\PBP3\DEVICE_REFERENCE\ PIC18F23K22.INFO
    What does the led look like? Does it look like it is on all of the time? I see no pause after turning it off. I would put a PAUSE 500 after the LOW LED1 statement.
    EN82fn
    Sep 2014
    First of all thank to longpole001 and Dave for reply.
    Before this post I read the datasheet of PIC18F23K22, the device.info, use melabs config and,try the same code with the rest of three devices purchased few days ago with no result seems like no powered microcontroller. I think make a mistake somewhere in the code but can't see where.The experimenter board used, have no faults on power, vcc decouple or mclr, xtal etc. I used this board many times on other proyects.
    Alex
    if you going to run it a 4mhz
    then
    CONFIG FOSC = INTIO67 instead of CONFIG FOSC = HSMP
    and
    OSCCON =$50
    and
    MainLoop:
    HIGH LED1
    PAUSE 500
    LOW LED1
    PAUSE 500 as dave said
    Goto Mainloop
    Sep 2014
    then
    and
    OSCCON =$50
    and
    MainLoop:
    HIGH LED1
    PAUSE 500
    LOW LED1
    Goto Mainloop
    Thank for reply Richard ,
    You are right , i used the default configuration and the led blink now , but as you can see this is a simple example. I want to use an external Xtal osc at 20 Mhz and from this point tried read the datasheet again for get the device working with external Xtal and frequency that i need .
    Thanks a lot ,
    Alex
    for ext 20mhz xtal
    CONFIG FOSC = HSHP
    OSCCON=0
    Sep 2014
    for ext 20mhz xtal
    CONFIG FOSC = HSHP
    OSCCON=0
    Hi Richard ,
    I use the following configuration in my Project for use only Primary Xtal Oscillator > 16 MHz
    CONFIG FOSC = HSHP ; HS oscillator (high power > 16 MHz)
    CONFIG PRICLKEN = OFF ; Primary clock can be disabled by software
    CONFIG WDTEN = ON ; WDT is always enabled. SWDTEN bit has no effect
    CONFIG EBTRB = OFF ; Boot Block (000000-0001FFh) not protected from table reads executed in other blocks
    DEFINE OSC 20 ' 20MHZ crystal
    OSCCON=%00001000 ' PRIMARY CLOCK DETERMINED BY FOSC<3.0> IN CONFIG 1H
    Alex
    OSCCON.3 is a read only bit indicating Oscillator Start-up Time-out Status
    OSCCON=0 is the correct option
    Just curious, why not use internal osc on 18F PIC?
    I do it all the time, works great even up to 64MHz on 18F4xK22 series
    Sep 2014
    Hi Robert thank you for reply.
    This is my first time using 18F series and choose this because only 28-pin dip and need work with two EUSART at high baud rates at the same time. Reading the datasheet sections 2.73 & 2.73.1 related to frequency drift and compensating with EUSART changes on OSCCON TUN<5:0> for adjust the clock frequency may be required.
    I like to know how OSCCON TUN work and and how to get 20Mhz clock.
    Alex
    Sep 2014
    Hi Richard ,
    Thanks a lot , i get the internal and external clock work correctly.
    Alex
    OSCTUNE will only adjust the internal osc and then only a few percent up/down . it will have no effect on an external crystal
    if you find PicMultCalc by misterE you can find correct usart settings and % baudrate timing error for any osc speed .
    as demon indicated more speed is good , why not engage the pll and run at 64mhz and save two pins too.
    I was thinking the only good reason for a 20mhz rock was to engage the pll and run at 80mhz or maybe to simplify some timing calculations, but just for baudrate stability no way
    Feb 2012
    PERTH AUSTRALIA
    Richard
    if a 20mhz xtl was on a 18F23k22 and the PPL was used , can that cpu actually run at 80mhz ?? , thought the cpu speed limit was set at 64mhz , as well as PBP at 64mhz , and the largest xtl supported was 16mhz ??
    cheers
    sheldon
    Guys have overclocked PICs, but Microchip can't guarantee stability.
    Pretty sure 64 is the highest for this PIC.
    you're right the specs say 64mhz max , but you can always have a go and see what happens
  1. HSERIN2 Problem on 18F23k22
    By ethobias in forum Serial
    Last Post: - 25th May 2011, 23:48
  2. High Speed Serial Comm PC - PIC and PIC - PIC
    By manumenzella in forum mel PIC BASIC Pro
    Last Post: - 16th January 2007, 21:55
