I can not help much for the web server problem, but here is what I know.
First you have to enable the web server with
Then you can access the module over your lan with, for example
http://192.168.2.63
and there is a pre-built page at
http://192.168.2.63/iChip
where some of the configs can be changed and files uploaded to the module if you have the
AT+iRPG
password set
["AT+iRPG=password",$d ,$a] ' SETS REMOTE PASSWORD
The default port is 80 for the server, the last I checked the port could not be changed. So depending on the capabilities of your router and other devices on your net work (maybe a real server on port 80) you may find it challenging to connect from the WAN.
And
If you go here
http://www.connectone.com/?page_id=306
You will find a config utility that will help in building and uploading web pages to the module.
That is all I got.
