iChip's Nano LanReach configuring problem
Results 1 to 8 of 8
    Apr 2012
    Ptolemaida
    Default Re: iChip's Nano LanReach configuring problem
    By the way Dave,
    doesn't this command "+iWEBP" change the webservers PORT ??
    If you read at page 71 of Programmer's manual at the command "+iWWW" it says:
    <n>=1..3
    1, 2 or 3 browser connections can connect simultaneously to iChip’s TCP port 80, or as defined in the WEBP parameter, implementing HTTP protocol.
    And continues with the command.....
    +iWEBP – Web Port
    Syntax:
    AT+iWEBP=<port>
    Sets the port number for iChip’s Web services. Remote browsers will need to open sockets to this port for Web services.
    Parameters:
    port=0..65535
    Command Options:
    port=0
    Use the well known port numbers: (80) for HTTP service or (443) for HTTPS service.
    port>0
    Use port number <port> for HTTP or HTTPS service.
    Default:
    0 (use well known ports)
    Result Code:
    I/OK
    If port is a legal value
    I/ERROR
    Otherwise
    AT+iWEBP?
    Returns current port number followed by I/OK.
    AT+iWEBP=?
    Returns the message “0-65535” followed by I/OK.
    AT+
    Best regards, Kostas!!
    One man's magic is ANOTHER man's engineering.
    Supernatural is a null word
    They made an update, WOOHOO!!!
    It has been awhile since I set one of these up, I guess I need to update manuals and firmware.
    Thanks for the information!!!!!
    Apr 2012
    Ptolemaida
    I am happy being able to help !! Now i get back in studying server, transfer protocols, Nat system and other stuff :P:P
  1. Help with configuring
    Last Post: - 17th August 2014, 02:08
  2. Nano SocketLAN connection to PIC
    By LGabrielson in forum mel PIC BASIC Pro
    Last Post: - 20th June 2012, 19:14
  3. My Rube Goldberg mount for the nano LanReach
    By dhouston in forum Ethernet
    Last Post: - 29th May 2011, 01:33
  4. 18F2520 - problem configuring fuse for port B as digital port.
    By hwhisperer in forum mel PIC BASIC Pro
    Last Post: - 11th October 2010, 12:41
  5. Configuring register problem
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2005, 21:03
