Bizarre compile errors
Results 1 to 4 of 4
    Aug 2014
    Default Bizarre compile errors
    Hi All,
    New to PIC Basic programming. I'm starting with examples for my PIC16F877A development board.
    I copied the 7 segment display example from here:
    http://melabs.com/samples/PBP-mixed/7segment.htm
    The first time I compiled it (at work), it compiled fine.
    I went home and changed a port assignment and it failed to compile.
    Next day I tried again at work, it failed to compile on exactly the same machine I had successfully compiled it on the previous day.
    I re-copied from the site and cut it down to just the erroring code to keep it simple and now I have two visually identical bits of code, one that compiles and one that doesn't.
    Now I could run with the one that does but as a beginner I really want to know what the hell is going on.
    Please see the attached screenshots.
    Cheers,
    Wilson.
Size:  126.5 KBName:  compiles.jpg
    Apr 2011
    Welches, Oregon
    Default Re: Bizarre compile errors
    One is compiling for a 12F, the other for a 16F. There is no PORTB in a 12F683, hence the issue.
    Aug 2014
    Doh!
    Wilson.
    Apr 2011
    Welches, Oregon
    Yay! One I can answer! Thank You!
  1. How to Figure Out Compile Errors?
    By RossWaddell in forum mel PIC BASIC Pro
    Last Post: - 25th February 2013, 18:54
  2. Usart compile errors 18F4520
    By Pedro Pinto in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 23:13
  3. USB PBPL Compile errors
    By Rob in forum USB
    Last Post: - 7th April 2008, 08:18
  4. USB Mpasm Compile errors
    By JBrannan in forum mel PIC BASIC Pro
    Last Post: - 21st December 2007, 18:13
  5. Compile errors within macro....
    By forgie in forum mel PIC BASIC Pro
    Last Post: - 5th September 2005, 19:08
