Pic18f4550 hserout
Results 1 to 3 of 3
    Default Pic18f4550 hserout
    Hi Guys, Wonder if any one can point out the difference between the PIC18 and PIC 16 HSEROUT commands.
    I normally use the following code in my PIC 16 programs,
    '*Serial port Setup 9600 8E1*
    DEFINE HSER_BAUD 9600 ; 9600 Baud
    DEFINE HSER_BITS 9
    DEFINE HSER_EVEN 1
    DEFINE HSER_CLROERR 1 ; Clear overflow automatically
    I now want to make use of a PIC18F4550
    the following code work at 38000 baud
    '*Serial port Setup 3800 8N1*
    DEFINE HSER_SPBRG 56 ' 38400 Baud @ 48MHz, -0.16%
    SPBRGH = 1
    BAUDCON.3 = 1 ' Enable 16 bit baud rate generator
    Is there any way I can get it configured to run 9600 8E1, I have tried changing the HSER_SPBRG value but with no success I also want to activate the parity.
    Any leads would be welcomed.
    Default Re: Pic18f4550 hserout
    No reason why you couldn't. Have you made sure you're not missing any CONFIG? Try to blink an LED first when in doubt.
    Have you tried Mr E's USART Utility to generate the DEFINES?
    Last edited by Demon; - 8th September 2014 at 20:29. Reason: MultiCalc: http://www.picbasic.co.uk/forum/showthread.php?t=4994
    It seems to be the 16 bit baud rate generator that is creating the problems as soon as you disable it everything works
  1. 2 pic18f4550 connection
    By aqieera in forum mel PIC BASIC
    Last Post: - 18th November 2011, 02:04
  2. PIC18F4550 help please
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 19:14
  3. PIC18f4550 error
    By williamlaw in forum Off Topic
    Last Post: - 14th May 2009, 19:27
  4. DS18B20 and PIC18F4550
    By sjohansson in forum mel PIC BASIC Pro
    Last Post: - 19th April 2006, 19:57
  5. PIC18F4550 rebooting
    By RubenR in forum mel PIC BASIC Pro
    Last Post: - 27th September 2005, 11:19
