how to access and set bits in a byte array?
Results 1 to 10 of 10
    Default Re: how to access and set bits in a byte array?
    pretty much
    bArrRGBData.0[8] is bit 0 of bArrRGBData[0] bit 0 + 8 bits , ie bArrRGBData[1] bit 0
    you can place it in any var but its value can only be 0 or 1
    can also be used as a logical value ie.
    if bArrRGBData.0[8] then dosomething
    doanotherthing
    just a warning pbp does not ckeck the boundary conditions of this type of indexing
    if you were to
    go
    bArrRGBData.0[41] =1
    there is no error message and anything in the next ram/register position from bArrRGBData[4] would be wrecked
    pretty much
    doanotherthing
    thanks for you help, am removing some rust here due to inactivity
    what bothered me for a bit (pun intended) was whether this would by syntax return a single bit, i realize now that the .0 portion says that and explaining that bArrRGBData.0[8] is equivalent to bArrRGBData[1] bit 0 is just what i needed
    i also understand the risk about overrunning the allocation
    how about these cases
    MyWordArray VAR WORD[8]
    what does the following do exactly ?
    MyWordArray = 0
    does it set the first byte of the Array to 0 and leaves the rest as was ?
    what if there is a word variable used instead
    AWord VAR WORD
    AWord = 0
    MyWordArray = AWord
    now are the first 2 bytes set to 0 ?
    just curious ....
  1. How do I check (or set) a group of consecutive bits within a byte?
    Last Post: - 2nd April 2012, 09:13
  2. Problem with bits in byte array....
    By HenrikOlsson in forum mel PIC BASIC Pro
    Last Post: - 19th October 2011, 07:27
  3. Access array in PBP and .asm
    By JEC in forum mel PIC BASIC Pro
    Last Post: - 6th September 2008, 01:35
  4. reading first four bits of a byte
    By kamet in forum mel PIC BASIC Pro
    Last Post: - 2nd January 2007, 09:50
  5. Word array behaving like byte array.... wierd
    By forgie in forum mel PIC BASIC Pro
    Last Post: - 2nd August 2005, 16:43
