Picbasic/18F/internal data-EEPROM capacity > 1kbyte?
Results 1 to 7 of 7
    Miami, Florida USA
    Default Re: Picbasic/18F/internal data-EEPROM capacity > 1kbyte?
    Like towlerg already said above, the external SPI EEPROM is the way to go. It is also easy to implement.
    Anonymous
    Sep 2009
    You can use PIC internal FLASH memory to store data, using READCODE/WRITECODE/ERASECODE.
    True, but be aware of limitations of write operations to code memory.
    Mar 2014
    England
    Many thanks, friends, for the collective advice - all of it valuable.
    You have solved the problem!
    For this particular application, the writecode/readcode will get me out of trouble for prototyping; and in the revised circuit board I will use an external EEPROM.
  1. Internal Eeprom/flash , what are you doing ?
    By ultiblade in forum mel PIC BASIC Pro
    Last Post: - 21st October 2008, 08:51
  2. 9V battery capacity question
    By luminas in forum Off Topic
    Last Post: - 19th August 2008, 17:02
  3. internal eeprom in pic16F628
    By Pedro Pinto in forum mel PIC BASIC Pro
    Last Post: - 5th December 2005, 07:21
  4. Internal EEPROM Read/write Addressing Errors with 18F PIC's
    Last Post: - 12th July 2005, 20:42
  5. 18F252 internal EEPROM / DATA, READ
    By NavMicroSystems in forum mel PIC BASIC Pro
    Last Post: - 1st June 2004, 15:01
