Internal pullups on 18F45K22
Results 1 to 3 of 3
    Mar 2014
    England
    Default Internal pullups on 18F45K22
    I'm going round in circles trying to find how to set the weak pullups on Port B of the 18F45K22.
    It seems to involve INTCON2 to enable the pullups; and WPUB to set the individual bits.
    Could anyone assist with the correct syntax that will get through the PBP3 compiler?
    Thank you!
    Default Re: Internal pullups on 18F45K22
    Hi
    You can add these lines to your code to enable pull-ups
    TRISB = %11111111 ' Portb set to input
    WPUB = %11111111 'all pull ups on portb enabled
    INTCON2.7 = 0 ' 0 = enabled, 1 = off
    Mar 2014
    England
    Default Re: Internal pullups on 18F45K22 - SOLVED!
    Hi Mark,
    Thank you for this: I had tried every similar variation but failed to make it work!
    Problem solved!
  1. Unknown Processor(18f45k22)
    By Azreel420 in forum mel PIC BASIC Pro
    Last Post: - 15th August 2014, 14:47
  2. Replies: 8
    Last Post: - 27th June 2013, 05:13
  3. Internal pullups 16C72
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 23rd December 2011, 18:57
  4. 16C65B internal pullups
    Last Post: - 20th January 2009, 17:26
  5. Effects of Current Draw Using Internal VS External PullUps
    By rixtalbert in forum mel PIC BASIC Pro
    Last Post: - 16th September 2006, 10:43
