MPASM Error Message
Results 1 to 6 of 6
    Default Re: MPASM Error Message
    Hi Angus,
    Considering all MPASM errors are assembly errors, and IF they correctly worked in PBP 2.5 my best advice is to look carefully at your config settings. Try deleting the config in your code and see if it compiles with success. Otherwise I would need to SEE your code. PBP issues will report, likely in red . . .
    Many times errors report as xxx.asm with a line number. you can open the yourfilename.ASM page and scroll to that line number.
    Look for a label or variable named Rollover in your code. Or I should say a label or variable called in your code that is not defined in your code.
    My first thought too Dave, seems like it would not compile in 2.5 with that error, wondering if this is "found code" and/or if there is a missing include file.
    Thanks Archangel, macmackit,
    Based on your suggestions I examined the include file INT-TIM0.PBP
    The "ROLLOVER" was the DEFINED label for the Interrupt handler
    The manual says this is case sensitive, and when I capitalised the label ROLLOVER at the start of the asm routine it all worked
    Seems that in V2.5 the label does not need to be capitalised, whereas in V3 it does :-)
    Many thanks for the suggestions
    Angus Anderson
    Could be in the way MCS is / was setup. Auto capitalize can be a problem. That is a feature that can cause bugs.
  1. Shift Function gives MPASM error
    By blackwood in forum mel PIC BASIC Pro
    Last Post: - 27th September 2010, 09:45
  2. Error message???
    By dangill in forum mel PIC BASIC Pro
    Last Post: - 11th February 2009, 12:53
  3. MPASM error message
    Last Post: - 3rd April 2008, 15:24
  4. error message
    By chip_select in forum mel PIC BASIC Pro
    Last Post: - 21st March 2008, 08:14
  5. Mpasm Error 5955
    By mungam753 in forum mel PIC BASIC Pro
    Last Post: - 9th December 2005, 05:47
