Config help
Results 1 to 10 of 10
Thread: Config help
    Jun 2013
    Default Config help
    I need to use a crystal of 12 MHz for my project,I read the PBP manual and it state that if the crystal is beyond 4Mhz ,a HS config must be set or the MCU may not work,But they are very limited resource in the manual about config,is there any resource available on the command?
    Thank you
    Default Re: Config help
    Not wanting to sound like a smart-ass but since you asked for a resource I'm going to send you right back to the manual. Section 4.9 covers the #CONFIG/#ENDCONFIG directive in some detail and there's quite a bit of information on this forum.
    Jun 2013
    Yes,I read it,it do have some example,but what all those word means?
    CONFIG XINST = OFF
    CONFIG PLLDIV = 5
    CONFIG WDTPS = 512
    CONFIG CPUDIV = OSC1
    This is part of the example,what is all those word after config means,why 512'why 5?what to be set off,there are no explanation ,what all those number means?
    And most of all,how to set the MCU to operate at 12mhz?obviously is not Define osc 12.i tried
    as has been discussed thousands of times osc must be in upper case ( OSC) and only tells the compiler what osc frequency to base its timing calculations on.
    CONFIG XINST = OFF
    CONFIG PLLDIV = 5
    CONFIG WDTPS = 512
    are config word (sometimes refered as fuse ) settings for a particular pic chip , they must match the chip you are using and the particular configuration that you want it to adopt.
    read the data sheet .
    consult your manual on methods of setting the "config word(s) " for your chip
    Jun 2013
    I found something interesting to read,about the config
    http://melabs.com/support/config_defaults.htm
    if you need more help you will get a better result by providing the forum with your pbp version , the chip you are using and the actual code (in code tags) you have tried
    Hi Sabahan,
    What Richard said is critical as Configs are handled differently in PBP 3.xx over any prior version. The HS in the config statement simply turns up the power to the OSC so as to enable it to run faster. As stated above DEFINE OSC 12 simply makes PBP aware of the change from default 4 mhz, and has no effect on the actual OSC.
    Quote Originally Posted by Sabahan View Post
    CONFIG XINST = OFF
    CONFIG PLLDIV = 5
    CONFIG WDTPS = 512
    Some reading if you are still on PBP v2.6 or earlier:
    http://www.picbasic.co.uk/forum/showthread.php?t=15982
    Jun 2013
    I'm using PBP3,seems that there are not much info on the net on this topic
  1. config
    By n0yox in forum PBP3
    Last Post: - 10th June 2014, 08:07
  2. PIC12F675 - config
    By Vezito in forum mel PIC BASIC Pro
    Last Post: - 8th June 2011, 20:29
  3. ADC Config
    By TrevorDawes in forum mel PIC BASIC Pro
    Last Post: - 19th April 2010, 01:34
  4. config help please?
    By karenhornby in forum mel PIC BASIC Pro
    Last Post: - 17th June 2008, 23:49
  5. Need help with config
    By Darrenmac in forum mel PIC BASIC Pro
    Last Post: - 25th February 2008, 06:57
