18F14K50, PORT C as outputs
Results 1 to 17 of 17
    Feb 2012
    Default Re: 18F14K50, PORT C as outputs
    New test:
    REFCON0=0
    REFCON1=0
    ADCON1=0
    ADCON2=0
    ANSEL =0
    ANSELH=0
    CM1CON0=0
    CM2CON0=0
    SRCON0=0
    SRCON1=0
    WPUA=0
    WPUB=0
    TRISC = 0
    PORTC = 0
    ProgStart:
       PORTC = 0
       PORTC = 255
       goto ProgStart
    PORTC.3, C.6 and C.7 work, PORTC.0, C.1, C.2. C4 and C.5 don't...
    So... what's the common factor?
    I've been looking thru the datasheet to figure out what might be going on but I honestly can't find it.
    So, I'm going to sugest that you might have a hardware issue, is this on a breadboard by any chance? Faulty contacts?
    Going thru the datasheet I also noted the follwing regarding setting all those registers to 0 in your code:
    REFCON0=0 (pg.247)
    Defaults to 16 at POR which means that the FVR is set to 1.024V but disabled, setting it to 0 shouldn't be needed.
    Instead, it specifically says not to use the value 0....
    REFCON1=0 (pg.248)
    Defaults to 0 at POR, DAC disabled, setting it to 0 shouldn't be needed.
    ADCON1=0 (pg.216)
    Defaults to 0 at POR, setting it to 0 shouldn't be needed.
    ADCON2=0 (pg.217)
    ANSEL = 0 (pg.98)
    Defaults to 248 at POR, setting it to 0 IS needed to enable the digital input buffers.
    ANSELH = 0 (pg.99)
    Defaults to 15 at POR, setting it to 0 IS needed to enable the digital input buffers.
    CM1CON0=0 (pg.229)
    Defaults to 0 at POR, comparator is disabled, setting it to 0 shouldn't be needed.
    CM2CON0=0 (pg.230)
    SRCON0=0 (pg.242)
    Defaults to 0 at POR, SR latch is disabled, setting it to 0 shouldn't be needed.
    SRCON1=0 (pg.243)
    WPUA=0 (pg.86)
    Defaults to 56 at POR, PortA pulups enabled, setting it to 0 disables the pullups individually.
    However, INTCON2.7 is the "master switch" PortA and PortB pullups and it defaults to 1 which means pullups are disabled.
    So, if you're NOT clearing INTCON2.7 there shouldn't be any need to set WPUA=0
    WPUB=0 (pg.91)
    Defaults to 240 at POR, PortB pullups enabled, setting it to 0 disables the pullups individually.
    However, INTCON2.7 is the "master switch" PortA and PortB pullups and defaults to 1 which means pullups are disabled.
    Feb 2012
    Thank you Henrik for your time and effort.
    I think you are right, setting states that are the same as after POR are not very useful...
    I think I give up for today. Tomorrow there's an other day...
    Have you tried AllDigital?
    http://www.picbasic.co.uk/forum/showthread.php?t=11100
  1. 18f14k50 low speed
    By mpardinho in forum mel PIC BASIC Pro
    Last Post: - 21st May 2013, 19:20
  2. Hello World help please 18F14K50 config
    By Bonxy in forum mel PIC BASIC Pro
    Last Post: - 4th August 2011, 18:35
  3. Replies: 2
    Last Post: - 22nd January 2011, 02:58
  4. 18F2520 - problem configuring fuse for port B as digital port.
    By hwhisperer in forum mel PIC BASIC Pro
    Last Post: - 11th October 2010, 12:41
  5. Replies: 3
    Last Post: - 24th September 2010, 08:10
