CHEAP wifi modules, at last!
Results 1 to 29 of 29
    Default Re: CHEAP wifi modules, at last!
    Well folks, this comes close enough to get you started.
    http://www.instructables.com/id/Usin...SP8266-module/
    Yes, found that too and have now been able to "manually" connect to my WiFi and serve up a most basic web-page using the terminal program in MCSP and a USB to UART dongle (no PBP code involved yet).
    Couple of random notes partly from info I've found and partly from experience.
    My module is the little blue one with a 2x4 pin header on it.
    * Make sure you use a dongle/adapter that outputs 3.3V, not 5V!
    * If you have a red and a blue LED on the board it's a V090 (using 115200 baud), if you don't have the LEDs you have a V080 (using 57600). (See here
    * On the V090 module the Ch_PD I/O needs to be tied to (or pulled up to) Vcc.
    * The USB dongle I was using wasn't able to provide enough power at it's 3.3V Vcc setting. Had to use external power supply.
    * Watch the Tx and Rx markings. Mine seems to reversed (ie I had to connect Tx on the module to Tx on the dongle) or I was just very tired and confused at the time. I haven't yet figured out if it's the module or the dongle that's marked incorrectly. Good thing is that nothing get damaged (as long as you're using 3.3V signals) so if it doesn't seem to want to talk to you you can always TRY reversing the connections.
    Next step will be to make up some sort of test rig with a PIC with two USARTs, one for interfacing to the module and one for interfacing to the PC.
    Thats good valuable information, Henrik. Thanks.
    Henrik, I'm trying to connect the module to a terminal emulator. I have a true serial port on my PC (not a USB-to-serial).
    I understand I'll have to use a level shifter. But, would I also need to invert the signals? Or just resistor(s) in the Tx/Rx lines?
    Sep 2009
    You need MAX3232.
    You'd need to invert and level shift them.
    I'd recommend using something like this. (Many many alternatives available of course but make sure it's designed to work at 3.3V).
    I'd like to clarify that the dongle I used isn't a "USB to RS232" one but a "USB to UART", this one to be precise.
    EDIT: Oops, pedja089 posted while I was typing and getting distracted with other things....
    Thanks, guys! Got the chap running. Extra thanks to Henrik for pointing out that Ch_PD I/O needs to be pulled high. I had missed that.
    Serial comms with terminal work ok.
    Can see the module on my Android.
    COULD see the routers (mine, and ones in the vicinity) with the AT+CWLAP.
    Could connect with my router after specifying SSID and the password.
    BUT, after that, AT+CWLAP no more lists the routers around; module seems to hang with a "busy now' response to any query.
    All other AT commands still work.
    Wonder what is happenning? (Module is connected to my router, confirmed that using AT+CWJAP?)
    Wonder how to erase my router from the module's eeprom? That might make the AT+CWLAP start listing the routers around again.
    Perhaps time to enlist on the ESP82666 forum.
    Okay, problem solved.
    I had inadvertently given a wrong password for my router, and the module would keep on trying to log on continuously.
    Used the AT+CWQAP, re-defined my SSID and password, and it works as it should.
  1. 2.4 ghz WiFi ID
    By tazntex in forum Ethernet
    Last Post: - 16th January 2013, 17:01
  2. Replies: 0
    Last Post: - 20th September 2011, 03:31
  3. cheap gsm modules
    By isaac in forum GSM
    Last Post: - 15th June 2007, 09:18
  4. supply FSK COB modules and FSK modules
    By Elsa zhang in forum Adverts
    Last Post: - 8th August 2006, 06:40
