CHEAP wifi modules, at last!
Results 1 to 29 of 29
    Default Re: CHEAP wifi modules, at last!
    Almost 2 months after placing my order, and almost after giving up hopes of delivery, the modules arrived today!
    I tried googling for any reference to PBP and EN8266, but did not get anything meaningful.
    Wondering if anybody has managed to make any progress in this direction?
    Join esp8266.com (I'm assuming you made a typo), all the info available, bugs, translation, projects. Oh, I see somebody already said that, my bad.
    George
    Oops! ESP8266 it is.
    I did visit that forum, and its rich with information.
    Quite a learning curve, though..
    Got three in the mail today, ordered a couple of weeks back. Will have to wait and see when I get time to play with them....
    Great! Looking forward to your observations.
    Well folks, this comes close enough to get you started.
    http://www.instructables.com/id/Usin...SP8266-module/
    Yes, found that too and have now been able to "manually" connect to my WiFi and serve up a most basic web-page using the terminal program in MCSP and a USB to UART dongle (no PBP code involved yet).
    Couple of random notes partly from info I've found and partly from experience.
    My module is the little blue one with a 2x4 pin header on it.
    * Make sure you use a dongle/adapter that outputs 3.3V, not 5V!
    * If you have a red and a blue LED on the board it's a V090 (using 115200 baud), if you don't have the LEDs you have a V080 (using 57600). (See here
    * On the V090 module the Ch_PD I/O needs to be tied to (or pulled up to) Vcc.
    * The USB dongle I was using wasn't able to provide enough power at it's 3.3V Vcc setting. Had to use external power supply.
    * Watch the Tx and Rx markings. Mine seems to reversed (ie I had to connect Tx on the module to Tx on the dongle) or I was just very tired and confused at the time. I haven't yet figured out if it's the module or the dongle that's marked incorrectly. Good thing is that nothing get damaged (as long as you're using 3.3V signals) so if it doesn't seem to want to talk to you you can always TRY reversing the connections.
    Next step will be to make up some sort of test rig with a PIC with two USARTs, one for interfacing to the module and one for interfacing to the PC.
  1. 2.4 ghz WiFi ID
    By tazntex in forum Ethernet
    Last Post: - 16th January 2013, 17:01
  2. Replies: 0
    Last Post: - 20th September 2011, 03:31
  3. cheap gsm modules
    By isaac in forum GSM
    Last Post: - 15th June 2007, 09:18
  4. supply FSK COB modules and FSK modules
    By Elsa zhang in forum Adverts
    Last Post: - 8th August 2006, 06:40
