CHEAP wifi modules, at last!
Results 1 to 29 of 29
    Default Re: CHEAP wifi modules, at last!
    Thanks for the forum link, Pedja. Didnt realize they'd already have a forum dedicated to this chap.
    BTW, there seem to be a couple of versions (different form-factors) available on ALiExpress. I notice a version that can also take external antennas.
    Anand
    Sep 2009
    It seems like that all firmware is in SPI FLASH memory, so there is no need for specific programmer. Compiler, firmware and some IoT example are available... So you can write your custom firmware... Or just write your own commands so PIC can do other task.
    Also it doesn't require almost any external component's so chip it should be very easy to integrate WiFi into product.
    I can't wait to get one and try it.
    Miami, Florida USA
    Excuse my ignorance here. But, how exactly does this work? Does it send data to a Web page that you need to set up first? Or, does it send data in form of a file to a remote server?
    Anonymous
    Sep 2009
    For client app, you connect to your AP, like you do with laptop, mobile phone, tablet.
    So you have access to internet.
    Then you connect to some address, eg google.com on port 80. And then using HTTP commands request page. You can use GET or POST command to get web page. Or you can post data to PHP script, using that two methods.
    Here is some HTTP examples http://www.jmarshall.com/easy/http/
    Other way is to use EMAIL, you connect to SMTP server to send email. You connect to port 25 of your server, eg smtp.yahoo.com port 25, and then log in using BASE 64 protocol for password, and send email.
    https://www.cs.cf.ac.uk/Dave/PERL/node175.html
    You can use putty to learn how to handle communication with server.
    If you are using module in AP mode, you connect to module with your tablet, or other device, and then create web page in pic, and than display it on your tablet.
    To do this, PIC must handle basic HTTP protocol. This is like setup page on router or AP.
    All this protocol are text based, so if you are familiar with using UART and parse string, this wouldn't be to hart to master. It isn't too hard. There is example with different module:
    http://www.picbasic.co.uk/forum/show...8906#post88906
    http://mackrackit.com/mac/ichip/ichip.html
    It's similar to GSM modem it isn't complicated as it might look.
    Miami, Florida USA
    Ooh, I see. Thank you for your nice explanation.
    Anonymous
    Almost 2 months after placing my order, and almost after giving up hopes of delivery, the modules arrived today!
    I tried googling for any reference to PBP and EN8266, but did not get anything meaningful.
    Wondering if anybody has managed to make any progress in this direction?
    Join esp8266.com (I'm assuming you made a typo), all the info available, bugs, translation, projects. Oh, I see somebody already said that, my bad.
    George
  1. 2.4 ghz WiFi ID
    By tazntex in forum Ethernet
    Last Post: - 16th January 2013, 17:01
  2. Replies: 0
    Last Post: - 20th September 2011, 03:31
  3. cheap gsm modules
    By isaac in forum GSM
    Last Post: - 15th June 2007, 09:18
  4. supply FSK COB modules and FSK modules
    By Elsa zhang in forum Adverts
    Last Post: - 8th August 2006, 06:40
