PWM on PORTG pin 3 on a 18F67k22
Results 1 to 13 of 13
Threaded View
  1. #8
    Feb 2012
    PERTH AUSTRALIA
    Default Re: PWM on PORTG pin 3 on a 18F67k22
    ok thanks richard i am tryng the to get a contrast control working for neg voltage , came across this example , see attached
    i still want to have a trim pot , which will set the default value so the lcd is viewable regardless , as well a setting it up via software , to get better viewable / allow temperature change
    have you come across other working examples for negative bios contrast controls
  1. PULSIN ON PORTF and PORTG ON 16F1947
    Last Post: - 9th December 2013, 01:54
  2. 16-48 pin Multi slow PWM
    By krohtech in forum mel PIC BASIC Pro
    Last Post: - 28th March 2009, 04:28
  3. Strange behavior - PORTG.2, 18F8720
    Last Post: - 12th January 2009, 00:30
  4. Multiplexing PWM pin with other outputs
    By bcd in forum mel PIC BASIC Pro
    Last Post: - 19th September 2006, 12:24
  5. pwm to pin using variable
    By wsmrite in forum mel PIC BASIC Pro
    Last Post: - 7th April 2006, 18:08
