Truth Tables in PBP
Results 1 to 19 of 19
Threaded View
  1. #4
    Sep 2009
    Default Re: Truth Tables in PBP
    If you need fast response you can create tables using arrays.
    For 4 bit system you have 16 different states, so you create array which hold data for output for every 16 states. And use 4 bits of ports for inputs, and outpust, eg portb0 to Portb3 is inputs, portA0 to 3 are outputs.
    TruthTable var byte[16] BANKA'So pbp doesn't need to put banksel after each command
    TruthTable[0]=%00001111
    TruthTable[1]=%00001100
    etc...
    TruthTable[15]=%00001111
    TRIS...
    ANSEL
    ETC..
    Tmp Var byte BANKA
    Tmp=portb & %00001111
    porta=TruthTable[Tmp]
    goto Main
    This will give almost fastest response for given clock speed.
    If you grounded upper nibble, this give you fastest possible responese
    porta=TruthTable[portb]
    goto Main
    If speed isn't critical you can assign bits to Tmp variable from any pin...
  1. tables using PBP and asm command retlw
    By queenidog in forum mel PIC BASIC Pro
    Last Post: - 7th June 2012, 22:47
  2. Help with two lookup tables?
    By awdgsx in forum mel PIC BASIC Pro
    Last Post: - 10th February 2012, 09:13
  3. Help with look up tables please
    By opticaltrigger in forum mel PIC BASIC
    Last Post: - 19th June 2010, 01:54
  4. Re:The Truth about Chernobyl Via Melanie
    By emmett brown in forum Off Topic
    Last Post: - 15th August 2006, 08:25
  5. Truth Tables
    By Rob Martin in forum mel PIC BASIC Pro
    Last Post: - 13th April 2005, 17:35
