Truth Tables in PBP
Results 1 to 19 of 19
    Sep 2007
    Waco, Texas
    Default Truth Tables in PBP
    Hey Everyone-
    I have queried this forum and have not found much in this area.
    I am attempting to 'clone' a logic board which cannot be purchased any longer and is no longer supported for a client. I have all the inputs and results for outputs but my main question is has anyone used a micro in place of logic gates?
    I have tried a couple of ways to provide inputs using IF/THEN type statements but it seems clunky and verbose.
    Almost think there may be a way to map inputs to EEPROM locations and read data straight out........
    Its pretty small; only 4 inputs and 3 outputs and a timing function of 2 seconds.
    Curious if anyone has tried to do this?
    Thanks in advance for any insight!
    "If we knew what we were doing, it wouldn't be called research"
    - Albert Einstein
    Default Re: Truth Tables in PBP
    four inputs
    could be
    a var portb.0
    b var portb.2
    c var porta.3
    d var portc.3
    outputs could be
    e var portc.0
    f var portc.1
    g var portc.2
    formula e = a or b and c ,f= d and c or b, g = b and c and d
    code
    e = (a or b)and c
    f= (d and c) or b
    g=(b and c)and d
    Select case cleans up on multiple if/then applications, on goto and on gosub work too.
    Sep 2009
    If you need fast response you can create tables using arrays.
    For 4 bit system you have 16 different states, so you create array which hold data for output for every 16 states. And use 4 bits of ports for inputs, and outpust, eg portb0 to Portb3 is inputs, portA0 to 3 are outputs.
    TruthTable var byte[16] BANKA'So pbp doesn't need to put banksel after each command
    TruthTable[0]=%00001111
    TruthTable[1]=%00001100
    etc...
    TruthTable[15]=%00001111
    TRIS...
    ANSEL
    ETC..
    Tmp Var byte BANKA
    Tmp=portb & %00001111
    porta=TruthTable[Tmp]
    goto Main
    This will give almost fastest response for given clock speed.
    If you grounded upper nibble, this give you fastest possible responese
    porta=TruthTable[portb]
    goto Main
    If speed isn't critical you can assign bits to Tmp variable from any pin...
    Sep 2007
    Waco, Texas
    Thanks Guys!
    While all are better than what I was playing with, I like the array scheme. I just don't do enough arrays to keep them front and center in my head.
    Unfortunately, I didn't have the presence of mind to neatly stack the inputs into a nibble on a port..... using A0, A1, A4, and A5 on a 16F616
    I do understand the philosophy, but there is one wrinkle; there are 2 cases in which I need to a pin high, time out for 2 sec and then go low. If the condition on the inputs pins stays the same, the timed pin just stays high.
    I even used DT's instant interrupts (so cool) to time the pin but that didn't seem to work.
    This should be so easy, but I am missing something and its probably so visible that I can't see it!
    What I get when I test my primitive code is the LEDs flash (I use them for debugging) and the timed pin never times out UNTIL the input condition changes. Snippit below:
              if command=1 and dpi=0 and bolt=1 and deadlck=1 then
                    t1=0 : t2=0 : t3=1     'leds
                    if tflag=1 then Main1X    'been here before so step around
                    unlock=0
                    unsecure=0
                    lock=1     'Turn ON sol
                    t1=0 : t2=1 : t3=0
                    pause 2000     'wait 2 sec
                    t1=0 : t2=1 : t1=1
                    lock=0     'Turn OFF sol
                    tflag=1     'We did it so set flag
                    t1=1 : t2=0 : t3=0
    Main1X:         t1=1 : t2=0 : t3=1
                    unlock=0
                    unsecure=0
    - Albert Einstein
    Jun 2009
    Sc*nthorpe, UK
    t2 is the timed pin?
    is tflag being reset to 0 elsewhere in your code?
    Like you I see no problem with this snippet.
    Could be RMW issue if those T# are on same port, better in that case to change them all at once like PortB=%00000100 PortB = %00000011
    Jun 2009
    Sc*nthorpe, UK
    Quote Originally Posted by ecoli-557 View Post
    Thanks Guys!
    There are ways around this.
    One is to use maths
    myvar=PORTA.0+PORTA.1*2+PORTA.4*4+PORTA.5*8
    Another way is bit manipulation
    myvar=PORTA & %00110011 ' select the input pins
    myvar=(myvar & %00000011) + (myvar & %00110000)>>2 'selects A0,A1 then selects A4 and A5 moves then to A2 and A3 and adds to A0,A1
    Another way is to set Aliases for the pins which relate to myvar. I will let you look into that one and I am sure there must be other workarounds.
    Then myvar can be used in LOOKUP to set an output pattern or used in SELECT CASE or IF THEN, the choice is yours.
    Sep 2007
    Waco, Texas
    Thanks Guys!
    I thought there had to be another way....
    BTW, it WAS a bug in my code that kept me from the timing sequence. I just tripped out all the code but the one conditional area - code worked like I thought it should.
    Then with the entire code back, I systematically remarked all the other places in the code where I zeroed the TFLAG bit var which was in all the other conditionals until it passed the var the way it should.
    Turns out you actually can not type using all thumbs! I had mistyped and it was staring me in the face.......
    Now that it actually works, its now going to be a learning experience and a life lesson to try these other ways so I may help someone down the road.
    Starting with arrays and trying the bit manipulation schemes.......
    Thanks and Regards.
    - Albert Einstein
    Jun 2009
    Sc*nthorpe, UK
    You are welcome and if you need more help, as always, just ask.
    Sep 2007
    Waco, Texas
    Thanks Steve.
    I have the array working now, thanks to Pedja089 (Thanks!) and thanks to Steve (EarlyBird2) I have the bit manipulation going.
    I have a solution using bit manipulation and Select Case statements which work completely and is more readable than my early attempts at multiple if the statements.
    The array idea works well except I can't seem to figure out the timing; on 2 inputs (9 and 11) I have a timing function where an output stays high for 2 seconds then goes low.
    For the array, I use
               Table            var byte[16] BANKA              'Array input is the value of the 4 inputs; 0-15 from the binary weight
               tflag            var table.3                     'timer flag
               TableIn          var byte                        'Entry into array from inputs
               temp             var byte                        'Temp var to use as a debounce
    and to get the table data is use
              Table[0]=6
              Table[1]=2
              Table[2]=6
              Table[3]=2
              Table[4]=6
              Table[5]=6
              Table[6]=6
              Table[7]=6
              Table[8]=5
    '          Table[9]=0
              Table[10]=5
    '          Table[11]=0
              Table[12]=4
              Table[13]=6
              Table[14]=6
              Table[15]=6
    And for the main part I tried to use
    '#	Subroutines
    Wait2sec: pause 2000
    get_input:
              TableIn=PORTA & %00110011                         'Selects the correct input pins
              TableIn=(TableIn & %00000011) + (TableIn & %00110000)>>2
        'Selects A0,A1 then selects A4,A5 moves to A2, A3 and adds to A0,A1
        'Therefore, the array entry is (Command - DPI - Bolt - Deadlck)
    '#	Startmain - where the MAGIC starts!
    Startmain:                                                  'Main wait loop
              gosub get_input                                   'Get inputs
              temp=TableIn
              gosub get_input
              if TableIn <> temp then goto startmain                'Var and temp var did not match so must have been noise, go back
              if TableIn = 9 then
                 unlock=0
                 unsecure=0
                 lock=1
                 pause 2000
                 lock=0
                 tflag=1
    Main1X:      lock=0
                 unlock=0
                 unsecure=0
                 goto startmain
              PORTC=Table[TableIn]                                  'Sets the port output to the table byte
              goto startmain                                    'Start all over
    I use the timing function which seems to work for 1 condition but when I type
    if TableIn = 9 or 11 then
    as a substitute for just 1 function, it bombs.
    The time flag beinig reset for all of the other conditions works for 1 condition but not for an OR condition?
    What am I missing now?
    -Steve
    - Albert Einstein
    Sep 2009
    If I was doing same thing I'll set outputs as needed on start of event 9 or 11...
    To detect start of event "9" and "11" you can use this code:
    IF TableIn=9 AND TableInLast<>9 THEN
    'Here you can do what ever needed
    ELSEIF TableIn=11 AND TableInLast<>11 THEN
     'Sttuf for event 11
    TableInLast=TableIn
    This way if you have continuous 9 or 11 on input, PIC won't be bricked doing pause...
    PAUSE 2000 will block pic to respond to other input states for 2 seconds. I don't know if that can cause problem... But there is way to make timings without using pauses.
    First set outputs, and then start timer. And on timer interrupt you turn off timer, and set outputs to default state...
    That is pretty easy using DTINT.
    but when I type if TableIn = 9 or 11 then as a substitute for just 1 function, it bombs.
    That won't work because what does If 11 then evaluate to? For that to work it needs to be
    IF (TableIn = 9) OR (TableIn = 11) THEN
    /Henrik
    Sep 2007
    Waco, Texas
    Hey There-
    I do have it working - came up late last night and my solution looks pretty much like Enrik's suggestion. Code follows for others to use or learn:
    'Variable List
               i                var byte                        'Loop counter var
    '#	We are going to setup this Pig!
    Initialize:
              unsecure=0                                        'Esures the relay is not active
              lock=0                                            'Ensures lock valve is not active
              unlock=0                                          'Ensures unlock valve is not active
              i=0
              Table[0]=6
              Table[1]=2
              Table[2]=6
              Table[3]=2
              Table[4]=6
              Table[5]=6
              Table[6]=6
              Table[7]=6
              Table[8]=5
    '          Table[9]=0
              Table[10]=5
    '          Table[11]=0
              Table[12]=4
              Table[13]=6
              Table[14]=6
              Table[15]=6
              goto Startmain                                    'Steps around the subroutines
    '#	Subroutines
    get_input:
        'Remembering that Command and DPI are ACTIVE LOW
        'When we get a command to open it is LOW, when door is closed=LOW
        'Bolt and Deadlck posotion sensors are ACTIVE HIGH
              temp=TableIn
              gosub get_input
              if TableIn = 9 then
                 unlock=0
                 unsecure=0
                 lock=1
                 pause 2000
                 lock=0
                 tflag=1
    Main1X:      lock=0
                 unlock=0
                 unsecure=0
                 goto startmain
    I really like the bit manipulation and the use of the tables - a lot.
    That's the good news, the not so good news is I have discovered 2 conditions which I hadn't counted;
    1. Coming out of the timed function, IF DPI goes from 0 to a 1, I just need to change state of the relay.
    IF after staying at 1, DPI goes back to a 0, then start the timing sequence again....... Dang.
    2. If after the timed section, if DPI=0 AND deadlock goes from a 1 to a 0 just change the relay state.
    Now that I have the truth table, understand the bit manipulation, got the array to work - now I find a 'transitional' state.
    Mickey Mouse logic in its day was pretty involved - almost as interesting as the relay-logic trees!
    Summation, thanks for the assist, I learned quite a number of 'finer' parts of PBP and registers.
    Now I am setting sites on how to know where I am, and watch for certain transitions......
    -Steve
    - Albert Einstein
    Sep 2007
    Waco, Texas
    OK, Ive been thinking (with the aid of a glass of Rye.....) and I was wondering with my re-newed knowledge of arrays if the following would work:
    1. Have built the truth table - works.
    2. Found that there are 'conditionals' within the truth table.
    3. What if (new thought here) that a bit or flag is set in the timing section which turns on or activates another section of table!?
    4. In my example (I will flesh out the table in the AM) that input 9 or 11 are the timed events. If I set a flag which I can add to the base address of 4 bits (a 5th) and use the newly addressed table for the 2 conditionals!!??
    OK, I don't know yet how to do this but tomorrow I will try several trys at this......
    Thoughts?
    - Albert Einstein
    Jun 2009
    Sc*nthorpe, UK
    Thoughts?
    Good thinking! Maybe I should try Rye.
    Obviously you could use all of the upper nibble as flags giving four sets of special cases if you set them as individual bits. By using the upper nibble as a value then fifteen special cases would be available.
    One complication, there is always at least one,
    TableIn is reset every time and the bits are manipulated. Obviously there is a workaround. More thinking is required, or Rye?
    Sep 2007
    Waco, Texas
    Ha! Clearly more of BOTH would be encouraged.......
    I'm re-making the truth table with the conditionals. I've always been better at diagramming and such - I'm sure a pattern may arise.
    Once I have the new 'map' I'll see what I can do.
    As far as TableIn=PORTA & %00110011, The dirty little secret DT showed me may come in handy for the INPUTS as well as it has for the OUTPUTS.
    The 'trick' is that the IO is sequential in the memory map, so, just set the base address:
    SYMBOL IN_PORT_PIN=PORTA ' starting address
    for x=0 to 4 'only 5 inputs for this chip
    IN_PORT_PIN.0=[x]
    next x
    OR just use alias - but that does 'bloat' the code......
    - Albert Einstein
    Sep 2007
    Waco, Texas
    OK-
    I've worked on this for a bit (no pun) and now I am finding out what the 'conditionals' are are actually edge-triggered events.
    I have code which works using flags and if-then-endif style, but my real question is does DT's Instant Interrupts work not only on level conditions - but also for edge level??
    I have gone to his page and looked it over, but I do not see any reference to edge-level interrupts.
    Should I now start a new thread?
    - Albert Einstein
    As far as I know all interrupts are edge triggered or "event triggered" if you will.
    Edge on input, mismatch on IOC pins, timer overflowing, byte in UART RX buffer, ADC finished etc.
    If you set the interrupt up to fire on the rising edge it will fire on the rising edge. If you then service the interrupt and clear the interrupt flag (which DT-INTS handles for you if you tell it to) it will NOT keep firing until there's a new rising edge on the input.
    What interrupt are you thinking of using that you thing may be "level triggered"?
  1. tables using PBP and asm command retlw
    By queenidog in forum mel PIC BASIC Pro
    Last Post: - 7th June 2012, 23:47
  2. Help with two lookup tables?
    By awdgsx in forum mel PIC BASIC Pro
    Last Post: - 10th February 2012, 10:13
  3. Help with look up tables please
    By opticaltrigger in forum mel PIC BASIC
    Last Post: - 19th June 2010, 02:54
  4. Re:The Truth about Chernobyl Via Melanie
    By emmett brown in forum Off Topic
    Last Post: - 15th August 2006, 09:25
  5. Truth Tables
    By Rob Martin in forum mel PIC BASIC Pro
    Last Post: - 13th April 2005, 18:35
