Basic stamp code does not works.
Results 1 to 14 of 14
    Default Basic stamp code does not works.
    Hello. I have the following basic stamp code:
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    MXCS PIN 0
    MXSO PIN 1
    MXSCLK PIN 2
    degCouple VAR Word
    degCinternal VAR Word
    TCtemp1 VAR Word
    TCtemp0 VAR Word
    faults VAR Nib
    SCVfault VAR faults.BIT2
    SCGfault VAR faults.BIT1
    OCfault VAR faults.BIT0
    DO
      LOW MXCS 'chip select low
        SHIFTIN MXSO, MXSCLK, MSBPRE, [TCtemp1\16,TCtemp0\16] 'shift in the data
      HIGH MXCS 'chip select high
      degCouple = TCtemp1 >> 2 + (-TCtemp1.BIT15 << 14)   ' the last term extends the sign bit
      degCinternal = TCtemp0 >> 4 + (-TCtemp0.BIT15 << 12)
      faults = TCtemp0.NIB0
      degCouple = (TCtemp1 >> 2) / 4
      DEBUG SDEC degCouple, TAB, SDEC degCinternal, TAB, BIN3 faults
      PAUSE 1000
      DEBUG CLS
    LOOP
    Since it is not fully compatible, I've modified faults VAR Nib to faults VAR Byte, and also, instead of "DEBUG", I'm using LCDOUT.
    Still does not works, returns 0 instead of temperature. When same hardware connected to BS2, the code works properly. Pinout seems to be correct. What else can be reason?
    Default Re: Basic stamp code does not works.
    I'd look at syntax in these statements first:
    MXCS PIN 0
    Then I'd check syntax of DO/LOOP in PBP manual.
    Oct 2009
    Utah, USA
    What PIC are you trying to use??
    What version of PBP are you compiling with?
    It's good that you posted the original basic stamp code but it would also be helpful if you posted the PIC code, as modified, that you are trying to run.
    Dwight
    When using stamp basic code that contains "modes" with PBP
    You need to add
    Include "modedefs.bas"
    Or change this
    to
    SHIFTIN MXSO, MXSCLK, 0, [TCtemp1\16,TCtemp0\16] 'shift in the data
    Hello CuriousOne,
    Very difficult to test this code having only 1/2 of the apparatus (for us). Here is what I would do . . . Add, include"BS2Defs.bas" change
    MXCS PIN 0 . . . to MXCS var PORTx. x etc . . . Change faults = TCtemp0.nib0 to faults = TCtemp0.lowbyte & try it, you might think good thoughts of linking US to the original project so we can get where you are.
    modedefs.bas is included. When I try to include bs2defs.bas, it gives error during compile on line next to it (no matter what is on there).
    here's the complete listing:
    '*  Notice  : Copyright (c) 2014 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 26.08.2014                                        *
    ADCON1=%00000110 'CONFIGURE PORT A AS DIGITAL
    Include "Modedefs.bas"
    'INCLUDE "BS2DEFS.BAS"
    Define	OSC	4		' Set Xtal Frequency
    	Clk     Var	portb.0		' Data is clocked on rising edge of this pin            kviteli
    	Dta  	Var	portb.1		' Bits are shifted out of this pin          stafilosferi
    	Load    Var	portb.2		' Transfers data to LEDs when Pulsed   lurji
        DQD Var portb.4              ' One-wire data pin FOR THERMOMETER
        ' ** Declare Constants **
    	Decode_Reg 	Con	9	' Decode register, a 1 turns on BCD decoding for each digit.
    	Lum_Reg		Con	10	' Intensity register.
    	Scan_Reg	Con	11	' Scan-limit register.
    	Switch_Reg	Con	12	' On/Off Register.
    	Test_Reg	Con	15	' Test mode register (all digits on, 100% bright)
    '	Max_Digit	Con	5	' Amount of LED Displays being used.
    ' ** Declare Variables **
      	Counter		Var	Word	' Variable used for the Demo Counting routine
    	Max_Disp	Var	Word	' 16-bit value to be displayed by the MAX7219
    	Max_Dp		Var	Byte	' Digit number to place Decimal point (0-4)
    	Register	Var	Byte	' Pointer to the Internal Registers of the MAX7219
    	R_Val		Var	Byte	' Data placed in Each Register
    	Digit		Var	Byte	' Position of individual numbers within MAX_Disp (0-3)
    	Position	Var	Byte	' Position of each LED display (1-4)
    temperature  Var Word       ' Temperature storage
    pause 50
     'Alias pins - MAX31855 temp sensor
     MXSCLK var PORTC.1 'MAX31855 Clock
     MXCS var PORTC.2 'MAX31855 Chip Select
     MXSO Var PORTC.3 'MAX31855 Serial Data
    degCouple VAR Word
    TCtemp1 VAR Word
    TCtemp0 VAR Word
    faults VAR BYTE
    	Register=Scan_Reg		' Point to the Scan Register
    	R_Val=3				' send 3, (Four LED Displays 0-3)
    	Gosub Transfer			' Transfer this 16-bit Word to the MAX7219
    	Register=Lum_Reg		' Point to the Luminance Register
    	R_Val=1				' Send 5, (Value for Brightness)
    	Register=Decode_Reg		' Point to BCD Decode Register
    	R_Val=%00001111			' Decode the first 5 digits
    	Register=Switch_Reg		' Point to the Switch Register
    	R_Val=1				' Set to One, (switches the display ON)
    	Register=Test_Reg		' Point to the Test Register
    	R_Val=0				' Reset to Zero, (turns off Test mode)
    	Max_Dp=1			' Display number for Decimal Point
    	pause 50
    MAX_DISP=4321
    GOSUB DISPLAY
    PAUSE 500
    do
    GOSUB GRADUS
    max_disp=Tctemp1
    GOSUB DISPLAY
    PAUSE 20
    LOOP
    Display:
    	Digit=0						' Start at Digit 0 of Max_Disp Variable
    	For Position=4 to 1 step -1			' Start at Farthest Right of Display
    	Register=Position				' Place Position into Register
    	R_Val=Max_Disp Dig Digit			' Extract the individual numbers from Max_Disp
    	If Max_Disp<10 and Position=3 then R_Val=15	' Zero Suppression for the second digit
    	If Max_Disp<100 and Position=2 then R_Val=15	' Zero Suppression for the Third digit
    	If Max_Disp<1000 and Position=1 then R_Val=15	' Zero Suppression for the Forth digit
    	If Max_Disp<10000 and Position=0 then R_Val=15	' Zero Suppression for the Fifth digit
    	If Digit=Max_Dp then R_Val.7=1			' Place the decimal point, held in Max_DP
    	'lcdout $fe,$c0,"Reg:", #register, " VAL:",#R_Val, "   "
    	pause 20
    	Gosub Transfer					' Transfer the 16-bit Word to the MAX7219
    	If Digit>=3 then Digit=0			' We only need the first four digits
    	Digit=Digit+1					' Point to next Digit within Max_Disp
    	Next Position					' Close the Loop
    	Return						' Exit from subroutine
    ' Send a 16-bit word to the MAX7219
    Transfer:
      	Shiftout Dta,Clk,msbfirst,[Register,R_Val] ' Shift Out the Register first, then the data
      	pauseus 100
    	High Load				' The data is now acted upon
    	pauseus 100
    @	Nop
    @	Nop					' A small delay to ensure correct clocking times
    	Low Load				' Disable the MAX7219
    	Return					' Exit from Subroutine
    GRADUS:
      'faults = TCtemp0.NIB0
      'degCouple = (TCtemp1 >> 2) / 4
      'DEBUG SDEC degCouple, TAB, SDEC degCinternal, TAB, BIN3 faults
      PAUSE 1000
      'DEBUG CLS
    not sure what ver pbp u have but
    BS1DEFS.BAS and BS2DEFS.BAS
    already includes MODEDEFS.BAS. Do not include it again if one of these files is
    already included. The Mode numbers may be used without including this file. Some
    Modes do not have a name.
    from the pbp3 manual
    As per the manual, use either but not both, bs2defs IS for stamp code use.
    Yes, as you can see, I had one of them commented, so was enabling one at a time, to check the compatibility. And even with bs2defs.bas included, compiler gives error on "Faults var nib".
    I have PBP3
    Hardware is PIC16F870
    pbp3 has no var type of nibble as previously mentioned use type BYTE
    are you sure that code is for a max31855 ?
    because that code reads the chip temp not the THERMOCOUPLE temp
    Yes, it works just fine on BS2. The code reads both data, I just enabled single one, to see if problem is in reading.
    Try setting your TRIS register.
    It took me two days to figure out
    when connecting to BS2, I was reversing the pins, so pinout in code was correct for that code only. Everything works just fine, thanks!
    Well I mentionned pins in my post and I was first to reply so I'm taking credit for solving this.
  1. Newbie migrating from Basic Stamp to PIC
    By gertlind in forum PBP3
    Last Post: - 2nd October 2013, 19:46
  2. Moving from Basic Stamp and MIKROE basic to PicBasic PRO
    Last Post: - 6th March 2013, 06:27
  3. Yet another SERIN2 problem - Conversion from Basic Stamp
    By Fanias in forum mel PIC BASIC Pro
    Last Post: - 24th October 2012, 08:08
  4. PicBasic Pro to Basic Stamp conversion?
    By Kirk Fraser in forum mel PIC BASIC Pro
    Last Post: - 17th March 2011, 07:49
  5. Basic Stamp BS2 replacement?
    By tenaja in forum Schematics
    Last Post: - 17th November 2009, 18:27
