Single Button Menus and 4 Line LCDs
Results 1 to 1 of 1
Threaded View
    Feb 2010
    Default Single Button Menus and 4 Line LCDs
    Hi all
    Been helped a lot here over the years so time to hopefully do a bit.
    A Menu on one display and only one button to select.
    I build Audio Tube Amps. The latest effort has over a grand of 300B tubes so wanted to make sure all
    stays OK and allows turn off before any damage. A 16F886 at 20mHZ does that job well. The PIC first
    runs a setup sequence of filament heating followed by switching B+ after tests. The 4x20 LCD display
    then monitors vitals in a loop. And warns/shuts down if not within set limits. You can set these to
    suit and save. Or reset the safe defaults for display pause, B+ voltage and current, two internal
    temperatures and whatever else you want to monitor.
    Yes it's simple and not elegant. But as usual the most important thing is it does the job.
    The complete code is only 500 lines and well within the words limit for any expansion.
    SETUP: 'DISPLAY MENU CHOICES
    ' FOR SIMPLE CASES ALL THAT IS REQUIRED
    GOSUB CLEARALL  ' ALL 4X20 LINES
    PAUSE 1000 ' IMP. TO SETTLE BUTTON AFTER PRESS TO HERE FROM MAIN DISPLAY LOOP
    LCDOut $FE, $80+2, "++ Setup Menu ++"
    LCDOut $FE, $C0, "1:Defaults 2:Spare"
    LCDOut $FE, $94, "3:Max Values 4:Exit"
    X=0
    do Until MENU_BTN = 0 'PRESSED. HIGH IN H'WARE
        X=X+1
        LCDOut $FE, $D4, REP " "\20  'CLEAR LINE4 or USE A GOSUB CLEAR4
        LCDOut $FE, $D4+1, "Button to select:",DEC X
        PAUSE 2000
        IF X=4 THEN  X=0
    LOOP
    GOSUB BEEP 'SO USER KNOWS BUTTON ACCEPTED
    SELECT CASE X
        CASE 1
            PAUSE 2000   'TO SETTLE PRIOR NEXT
            GOTO DEFAULTS
        CASE 2
            PAUSE 2000
            GOSUB CLEARALL
            gosub BEEP
            LCDOut $FE, $C0+1, "Spare. Future Adds"
            PAUSE 3000
            GOTO MAIN
        CASE 3
            PAUSE 2000
            GOTO SETVALUES
        CASE 4
            PAUSE 2000
            GOSUB CLEAR4
            gosub BEEP
            LCDOut $FE, $C0+2, "No changes made"
            PAUSE 3000
            GOTO MAIN
        CASE ELSE
            GOTO MAIN
    END SELECT
  1. Single button function
    Last Post: - 4th April 2020, 19:33
  2. LCDs
    By Demon in forum Adverts
    Last Post: - 21st April 2012, 03:14
  3. Replies: 3
    Last Post: - 17th April 2007, 15:45
  4. Graphic LCDs
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 20th April 2004, 11:04
  5. 2 Line Chars on a 2 Line LCD
    By Squibcakes in forum mel PIC BASIC Pro
    Last Post: - 16th November 2003, 01:44
