Port A Issues
Results 1 to 3 of 3
Thread: Port A Issues
    Hangover, Germany
    Please check:
    Does PortA.4 require an Pull-Up-Resistance ?
    Did you trap into a read-modify-write-problem, because to output of PortA.1 is bad designed and the voltage on this output can't rise to 3,x Volt or more. Then this input is read as "0" and written as "0" while changing PortA.4 !
    www.sprut.de
    Apr 2005
    Virginia
    Thumbs up Solved!
    Okay, silly me had been looking at all the posts for overcoming the A/D features on the "a" ports and nearly everywhere I went, the example programs used ADCON1 = 7. Since I have a PIC18F2525, I have several more A/D ports (?) and needed to set all of these as digital I/O, not analog. Thus, the fix is:
    Adcon1 = $0F
    BigWumpus, thank you for the guidance.
    Hope this helps others!
  1. Change On Interrupt, PIC16F884
    Last Post: - 14th November 2008, 18:25
  2. output port issues driving LEDs
    By p15218 in forum mel PIC BASIC Pro
    Last Post: - 27th August 2008, 22:42
  3. port config.
    By tamertokgoz in forum mel PIC BASIC Pro
    Last Post: - 25th July 2008, 13:25
  5. STATUS re-curtain W
    By zugvogel1 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2005, 16:21
