Questions about using the A to D
Results 1 to 19 of 19
    Default Re: A to D reading confusion
    Hi Ed,
    Your previous ADC had a resolution of 12 bits, ie a value ranging from 0 to 4095.
    The PIC ADC has a resolution of 10 bits, ie a value ranging from 0 to 1023 in "steps" of 1 (0, 1 ,2 ,3, 4....) or from 0 to 65472 in "steps" of 64 (0, 64, 128, 192, 256...)
    If you divide 65472 by 16 you'll get 4092 which is pretty close to 4095 - that's the reason it "works" for you. And if you divide the "step size" of 64 by 16 you'll get 4 so when you see you're value "bouncing" +/- 4 counts it's really only "bouncing" +/- 1 LSB which is kind of expected.
    Try setting ADCON2.7 = 1 to right justify the result and see if you'll get a result from 0 to 1023 with "steps" of 1 instead. If needed, you can then get more resolution by oversampling. Take 16 readings, add them all up and divide by 4 to go from 10 bits to a "psuedo resolution" of 12 bits - for example.
    I'm not saying what you're doing is wrong - as long as it works for you I'm happy :-)
    I just wanted to clarify for you and others that might find your comment about the ADC is going from 0-65535 that the resolution of the ADC is NOT 16bits which you might think it is when reading your post.
    Jun 2009
    Sc*nthorpe, UK
    Interesting explanation Henrik. I was trying to work out how 0-65535 was achieved knowing that the PIC ADC was 10 bit. Reading the datasheet
    The module has five registers:
    • A/D Result High Register (ADRESH)
    • A/D Result Low Register (ADRESL)
    • A/D Control Register 0 (ADCON0)
    • A/D Control Register 1 (ADCON1)
    • A/D Control Register 2 (ADCON2)
    The ADCON0 register, shown in Register 17-1,
    controls the operation of the A/D module. The
    ADCON1 register, shown in Register 17-2, configures
    the functions of the port pins. The ADCON2 register,
    shown in Register 17-3, configures the A/D clock
    source, programmed acquisition time and justification.
    I was puzzling over the last word "justification" and the effect it would have. Now I know.
    Hi Steve, Ed,
    Just to clarify further, it can never return 65535 no matter how you configure it.
    It'll look like this, where x is the actual conversion result returned by the 10 bit ADC:
     ADRESH    ADRESL
    xxxxxxxx  xx000000	Left justified, ADCON2.7 = 0   (default)
    000000xx  xxxxxxxx	Right justified, ADCON2.7 = 1
    With left justification the two most significant bits in ADRESL are the two least significant bits of the 10 bit result.
    With right justification the two least significant bits in ADRESH are the two most significant bits of the 10 bit result.
    If you have the ADC set to left justification but look at the result as a "normal" 16 bit value each LSB of the ADC result will change the 16 bit value by 64 since the LSB of the ADC result is aligned with ADRESL.6.
    So, with left justification and the ADC saturated the maximum value it can return is 65472 since the 6 least significant bits in ADRESL will be 0.
    Mar 2011
    Los Angeles, California
    Hi Henrik!
    Again thank you! You are correct. I connected a 10K resistor from the +5v to the ADC input pin and got 65472! Probably should have done that first! Just wondering, any way to eliminate the "bounce"?
    Ed
    Hi Ed,
    Make sure that VRef is stable.
    In this case I think you're using Vdd as Vref so proper bypassing right at the supply pin(s) of the PIC. At Vdd/VRef=5V a difference of 4.88mV will make the ADC result "jump" a LSB. So any ripple larger than +/-5mV on the supply will be reflected on the readings.
    Make sure that you feed the ADC input from a low(ish) impedence circuit.
    If your sensor has a high output impedence you may need to buffer the signal with a OP-amp or whatever. Filter the sensor output then feed it to the buffer then to the ADC input.
    Or you can simply try throwing a 10-100nF capacitor right on the ADC input pin....
    Or just filter it in software.... which, again, will allow you to oversample and get more resolution (if needed).
    Remember, you're seeing a "bounce" of 4 (or 64 actually) but in reallity it's only a single LSB - and that's pretty normal.
  1. PicKit 2 Questions
    By dmairspotter in forum General
    Last Post: - 11th November 2007, 22:10
  2. 2 questions
    By Archangel in forum mel PIC BASIC Pro
    Last Post: - 1st December 2006, 03:47
  3. Serial questions
    By Armando Herjim in forum Serial
    Last Post: - 29th June 2006, 20:49
  4. New with questions
    By Terke in forum General
    Last Post: - 6th December 2005, 07:35
  5. Questions?
    Last Post: - 23rd June 2005, 15:44
