Definning a VAR for Different Register Bits
Results 1 to 5 of 5
    Miami, Florida USA
    Default Re: Definning a VAR for Different Register Bits
    Hmm, I was hopping it could be done using VAR or SYMBOL, since I don't have much free programming space in my chip.
    Anonymous
    Here is a 4 digit counting demo using the pic16f913. Hope it helps
    'PIC16F914  4 Digit LCD Counter Demo
    'Purpose to Drive non-inteligent LCD displays with on chip LCD module
    'Vishay VM404 LCD 4 digit, 7 segment  -mouser elect
    'LCD BIAS RESISTER LADDER 3x 47k VCC-VDD
    ' July 2006 Mark S
    DEFINE 	OSC		4		        ' Set Xtal Frequency
    CMCON0 =%00000111   'COMPARATOR OFF
    ADCON0 =%00000000   'ADC off
    'SET LCD REGISTERS
    LCDCON = %10010010 'LCD ENABLED,SLEEP-LCD ON,ERR OFF,BIAS ON,CLK F/8192,MUX 1/3
    LCDPS  = %00110000 ' SEE DATA SHEET
    LCDSE0  =%11111111  'SEGMENTS 0-7 ON
    LCDSE1  =%00001111  'SEGMENTS 8-11 ON 12-15 OFF
    LCDSE2  =%00000000 	'SEGMENTS 16 - 23 OFF
    'VARIABLES
    adval   VAR WORD
    XCOUNT  VAR WORD
    TEMPX   VAR WORD
    ONES    VAR byte
    TENS    VAR byte
    HUNS    VAR byte
    THOU    VAR byte
    DIG1	VAR	BYTE
    DIG2	VAR BYTE
    DIG3	VAR	BYTE
    DIG4	VAR BYTE
    DP1		VAR	BIT
    DP2		VAR BIT
    DP3		VAR BIT
    TRISA = %00000000
    TRISB= %00000000
    TRISC= %00000000
    TRISD= %00000000
    TRISE= %00000000
    'Clear LCD
         XCOUNT = 0
         LCDDATA0 = 0 : LCDDATA1=0 : LCDDATA2=0 : LCDDATA3=0
         LCDDATA4 = 0 : LCDDATA5=0 : LCDDATA6=0 : LCDDATA7=0
         LCDDATA8 = 0 : LCDDATA9=0 : LCDDATA10=0 : LCDDATA11=0
    'MAIN
     START:
    'Count loop 0 to 9999
     TEMPX = TEMPX + 1
        XCOUNT = TEMPX
        THOU = XCOUNT/1000
        XCOUNT = XCOUNT//1000
        HUNS = XCOUNT/100
        XCOUNT = Xcount//100
        TENS = XCOUNT/10
        ones = XCOUNT//10
    LCD OUT:
        'SEVEN SEG LOOKUP
        LookUp ONES,[63,6,91,79,102,109,124,7,127,103,0],DIG4
        LookUp TENS,[63,6,91,79,102,109,124,7,127,103,0],DIG3
        LookUp HUNS,[63,6,91,79,102,109,124,7,127,103,0],DIG2
        LookUp THOU,[63,6,91,79,102,109,124,7,127,103,0],DIG1
         LCDDATA6.0 = 1    'Decimal Point
        'LOAD LCD REGISTERS
          LCDDATA0.4 = DIG4.0	'D4A	=	LCDDATA0.4
          LCDDATA0.3 = DIG4.1    	'D4B	=	LCDDATA0.3
          LCDDATA3.3 = DIG4.2    	'D4C	=	LCDDATA3.3
          LCDDATA6.4 = DIG4.3   	'D4D	=	LCDDATA6.4
          LCDDATA3.5 = DIG4.4   	'D4E	=	LCDDATA3.5
          LCDDATA0.5 = DIG4.5  	'D4F	=	LCDDATA0.5
          LCDDATA3.4 = DIG4.6   	'D4G	=	LCDDATA3.4
          LCDDATA0.6 = DIG3.0   	'D3A	=	LCDDATA0.6
          LCDDATA0.2 = DIG3.1   	'D3B	=	LCDDATA0.2
          LCDDATA3.2 = DIG3.2  	'D3C	=	LCDDATA3.2
          LCDDATA6.6 = DIG3.3   	'D3D	=	LCDDATA6.6
          LCDDATA3.7 = DIG3.4   	'D3E	=	LCDDATA3.7
          LCDDATA0.7 = DIG3.5   	'D3F	=	LCDDATA0.7
          LCDDATA3.6 = DIG3.6   	'D3G	=	LCDDATA3.6
          LCDDATA1.0 = DIG2.0   	'D2A	=	LCDDATA1.0
          LCDDATA0.1 = DIG2.1   	'D2B	=	LCDDATA0.1
          LCDDATA3.1 = DIG2.2   	'D2C	=	LCDDATA3.1
          LCDDATA7.0 = DIG2.3   	'D2D	=	LCDDATA7.0
          LCDDATA4.1 = DIG2.4   	'D2E	=	LCDDATA4.1
          LCDDATA1.1 = DIG2.5   	'D2F	=	LCDDATA1.1
          LCDDATA4.0 = DIG2.6   	'D2G	=  	LCDDATA4.0
          LCDDATA1.2 = DIG1.0   	'D1A	=	LCDDATA1.2
          LCDDATA0.0 = DIG1.1   	'D1B	=	LCDDATA0.0
          LCDDATA3.0 = DIG1.2   	'D1C	=	LCDDATA3.0
          LCDDATA7.2 = DIG1.3   	'D1D	=	LCDDATA7.2
          LCDDATA4.3 = DIG1.4   	'D1E	=	LCDDATA4.3
          LCDDATA1.3 = DIG1.5   	'D1F	=	LCDDATA1.3
          LCDDATA4.2 = DIG1.6    	'D1G	=	LCDDATA4.2
         PAUSE 200
            'CLEAR LCD REGISTERS
         LCDDATA6.0 = 0 'DP
        IF XCOUNT = 9999 THEN ZERO_X
        GOTO START
        ZERO_X: XCOUNT = 0    'Reset counter
        GOTO START
    Miami, Florida USA
    Thank you guys. That code gives me some ideas for my own program.
    Anonymous
  1. Replies: 2
    Last Post: - 23rd April 2013, 16:34
  2. 7.6.5 Applying Offsets to Bits within a Variable or Register
    Last Post: - 30th November 2011, 07:27
  3. DT_INTS-14 /interrupts enable bits / flag bits
    By bogdan in forum mel PIC BASIC Pro
    Last Post: - 16th May 2009, 18:42
  4. assigning register bits to an array?
    By bakerajatha in forum mel PIC BASIC Pro
    Last Post: - 19th January 2009, 19:12
  5. calculate var Byte's and var Word's
    By Pedro Pinto in forum mel PIC BASIC Pro
    Last Post: - 31st October 2005, 09:29
