RFID RDM6300 Code.. Sample ?? Anyone ??
Results 1 to 9 of 9
    May 2012
    Merseyside, UK
    Exclamation RFID RDM6300 Code.. Sample ?? Anyone ??
    Hi Thank you for reading….
    I have recently got my self some of these to play with.. RDM630(0) Em4100 Serial Output
    http://imall.iteadstudio.com/im120618002.html
    Question :-
    There seems to be a lack of example code around the internet…. Has anybody used these with PBP?
    Am I right in just reading what the serial is squirting out somehow ??
    Is there any samples to look at ?
    BR and Thank you.
    Andy
    Default Re: RFID RDM6300 Code.. Sample ?? Anyone ??
    Jun 2009
    Sc*nthorpe, UK
    Here is a RFID example which uses serin to read 10 characters from a RFID reader.
    RFID by Ecoli-557
    Have a read and as usual if you need more help just ask.
    Jun 2009
    Sc*nthorpe, UK
    This is the example from the site in your original post it reads 14 tag IDs using I will look into converting this to PBP 2.5c for you.
    #include <p18lf26j11.h>
    #include <delays.h>
    #include <usart.h>
    #include <string.h>
    #pragma config OSC = HS //High speed crystal
    #pragma config WDTEN = OFF //Disable watchdog timer
    #pragma config XINST = OFF //Disable Extended CPU mode
    //LED Pin Configuration
    #define LED1Pin LATAbits.LATA0
    #define LED1Tris TRISAbits.TRISA0
    #define LED2Pin LATAbits.LATA1
    #define LED2Tris TRISAbits.TRISA1
    #define LED3Pin LATAbits.LATA2
    #define LED3Tris TRISAbits.TRISA2
    #define RFIDVCCPin LATBbits.LATB4 //Define RFIDVCCPin as PORT B Pin 4
    #define RFIDVCCTris TRISBbits.TRISB4 //Define RFIDVCCTris as TRISB Pin 4
    //Flags & Data Reception Variables
    volatile char tagRecdFlag;
    volatile char tagComingFlag;
    volatile char tagCounter;
    volatile char tagRX[14] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
    //RFID Tag IDs
    char rfidTag1[14] = {0x02, 0x30, 0x35, 0x30, 0x30, 0x41, 0x44, 0x44, 0x38, 0x46, 0x46, 0x43, 0x3f, 0x03};
    char rfidTag2[14] = {0x02, 0x30, 0x35, 0x30, 0x30, 0x41, 0x44, 0x42, 0x46, 0x35, 0x37, 0x36, 0x30, 0x03};
    char rfidTag3[14] = {0x02, 0x30, 0x35, 0x30, 0x30, 0x41, 0x45, 0x33, 0x46, 0x36, 0x35, 0x44, 0x33, 0x03};
    //Function Prototypes
    void rx_handler(void);
    #pragma code rx_interrupt = 0x8
    void rx_int(void)
        _asm goto rx_handler _endasm
    #pragma code
    #pragma interrupt rx_handler
        unsigned char rxByte;
        rxByte = RCREG1; //Read character received from USART
        if (tagComingFlag == 0 && rxByte == 0x02)
            tagRX[tagCounter] = rxByte;
            tagComingFlag = 1;
            tagCounter++;
        }   else if (tagComingFlag == 1)
                tagCounter++;
                if (tagCounter == 14)
                    tagCounter = 0;
                    tagComingFlag = 0;
                    tagRecdFlag = 1;
            }   else
                    tagComingFlag = 0;
                    tagCounter = 0;
        PIR1bits.RCIF = 0; //Clear interrupt flag
    void main()
            //Set LED Pins data direction to OUTPUT
            LED1Tris = 0;
            LED2Tris = 0;
            LED3Tris = 0;
            //Set LED Pins to OFF
            LED1Pin = 0;
            LED2Pin = 0;
            LED3Pin = 0;
            tagRecdFlag = 0; //Set in ISR if new RFID tag has been read
            tagComingFlag = 0; //Indicates if a tag is partially received
            tagCounter = 0; //Counts byte index
            //USART1 Initialization
            Open1USART(USART_TX_INT_OFF & USART_RX_INT_ON & USART_ASYNCH_MODE & USART_EIGHT_BIT & USART_CONT_RX & USART_BRGH_LOW, 25);
            //Interrupts
            RCONbits.IPEN = 1;  //Enable interrupt priority
            IPR1bits.RC1IP = 1;  //Make receive interrupt high priority
            INTCONbits.GIEH = 1; //Enable all high priority interrupts
            //Turn on RFID Module
            RFIDVCCTris = 0; //Set to output
            RFIDVCCPin = 1; //Turn on RFID Module
            while(1)
                if (tagRecdFlag)
                    //Toggle LED corresponding to which card was read
                    if (memcmp(tagRX, rfidTag1, 14) == 0)
                        LED1Pin = ~LED1Pin;
                    if (memcmp(tagRX, rfidTag2, 14) == 0)
                        LED2Pin = ~LED2Pin;
                    if (memcmp(tagRX, rfidTag3, 14) == 0)
                        LED3Pin = ~LED3Pin;
                    //Delay 1/2 sec & clear flags to prevent repeated card read
                    Delay10KTCYx(200);
                    tagRecdFlag = 0;
                    tagComingFlag = 0;
                    tagCounter = 0;
    Jun 2009
    Sc*nthorpe, UK
    After a bit more reading.
    14 bytes because the output includes
    a start byte - 02
    10 tag characters
    2 CRC bytes
    an end byte - 03
    so with serin2 wait for 02 character and then read 10 characters into tag buffer like this
    SERIN2 rfid_data, 396, [WAIT($02),STR buf\10]
    May 2012
    Merseyside, UK
    Hi..
    Thank you all for help..... I have just got something working ....
    Not quite sure how the number on the card relates to the hex number embeded in the card...Had to get that out via clever use of a MAX232 chip, hyperterminal and a few caps on the bench...!!
    Thank you all again...
    Jun 2009
    Sc*nthorpe, UK
    Quote Originally Posted by andybarrett1 View Post
    There is no relation except for the CRC. My understanding is that you have to swipe the cards and capture the embedded numbers (Tag) which you can then use in your code. The output from the RFID is TTL level and using a MAX232 is one way forward.
    I have read some posts that suggest the CRC is used to catch bad data but the datasheet says the CRC is calculated using the card number. Examples I have seen ignore the CRC and end byte. I guess the cards are reasonably reliable and do not need CRC checking or end byte detection, who knows?
    May 2012
    Merseyside, UK
    Quote Originally Posted by EarlyBird2 View Post
    That is what I will do…. Seems to be others have same issue..
    Thanks again for help
    Andy
    Hi Folks,
    I started to play with this RFID reader. For beginning I try to create a simple TAG reader and show the tag number on NOKIA LCD. I can read the tag and display it, but I can't extract the decimal value from readed HEX string. For example: TAG number written on tag is 0008201470 (dec) readed as 34007D24FE (HEX).
    My question is how to convert this HEX to DEC?
    Reading the TAG as HEX string:
    '*  Name    : RDM6300 RFID Reader, nokia LCD                    *
    '*  Notes   : PIC16F1829                                        *
    ;@ errorlevel -306
      __config  _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_ON & _FCMEN_OFF
      __config  _CONFIG2, _WRT_OFF & _PLLEN_OFF & _STVREN_ON & _BORV_19 & _LVP_OFF
    DEFINE OSC 16     ; Use a 16 MHZ internal clock
    OSCCON = %01111010
    OSCTUNE = %111111
    CLKRCON = 0
    APFCON0 = 0
    APFCON1 = 0
    CM1CON0 = 0
    FVRCON = %11000011
    ADCON1 = %00010000
    ADCON0 = %00000000
    CCP1CON = %00000000
    CCP2CON = %00000000
    ANSELA = %00000000
    ANSELB = %00000000
    ANSELC = %00000000
    TRISA =  %00100000
    TRISB =  %00100000
    TRISC =  %00000000
    CM1CON0 = 0       ; Disable comparator 1
    CM2CON0 = 0       ; Disable comparator 2
    OPTION_REG.6=0
    OPTION_REG.7=1    ;  weak pull ups
    clear
    DEFINE HSER_RCSTA 90h       ; Set receive register to receiver enabled
    DEFINE HSER_TXSTA 24h       ; Set transmit register to transmitter enabled
    DEFINE HSER_BAUD 9600
    BUFF VAR BYTE [11] bank1
    #DEFINE PIC16 1
    lcdheight  con 5                  ; 6 PAGES
    lcdwidth  con 83                  ; 84 PIXELS WIDE
    LCD_CLK     var     portC.0
    LCD_DIN     var     portC.1
    LCD_RST     var     portC.2
    LCD_DC      var     portC.3
    LCD_CE      var     portC.4
    LCD_LIGHT   var     portC.5
    sw1         var     porta.5
    buf	        VAR	    byte [10]
    include "nokia_ds2.INC"
    include "font7x5_16.bas"
    gosub lcd_init
    LCDCLR
    ;TAG No. Decimal: 0008201470
    hserin 100,main,[wait ($02), STR buf\10] ;wait for $02, then read 10 bytes ascii hex
    ;Reading in HEX: 34007D24FE
    bigtxt = 0
    ARRAYWRITE BUFF,[str buf] ;display on NOKIA LCD
    LCDSTR  0,0,BUFF
    Reading the TAG as five individual HEX byte:
    ;@ errorlevel -306
    OSCCON = %01111010
    OSCTUNE = %111111
    CLKRCON = 0
    APFCON0 = 0
    APFCON1 = 0
    CM1CON0 = 0
    FVRCON = %11000011
    ADCON1 = %00010000
    ADCON0 = %00000000
    CCP1CON = %00000000
    CCP2CON = %00000000
    ANSELA = %00000000
    ANSELB = %00000000
    ANSELC = %00000000
    TRISA =  %00100000
    TRISB =  %00100000
    TRISC =  %00000000
    OPTION_REG.6=0
    clear
    BUFF VAR BYTE [10] bank1
    #DEFINE PIC16 1
    LCD_CLK     var     portC.0
    LCD_DIN     var     portC.1
    LCD_RST     var     portC.2
    LCD_DC      var     portC.3
    LCD_CE      var     portC.4
    sw1         var     porta.5
    b0 var byte
    b1 var byte
    b2 var byte
    b3 var byte
    b4 var byte
    gosub lcd_init
    LCDCLR
    hSERIN 100,main,[wait ($02),hex2 b0, hex2 b1, hex2 b2, hex2 b3, hex2 b4] ; ;wait for $02, then read 10 bytes ascii hex
    ARRAYWRITE BUFF,[hex2 b0, hex2 b1,hex2 b2, hex2 b3,hex2 b4] ;display on NOKIA LCD
    LCDSTR  0,0,BUFF
    gOTO main
  1. Please help with sample code on 12f675
    By critix in forum mel PIC BASIC Pro
    Last Post: - 18th June 2013, 04:08
  2. please who can help me for sample code
    By jasem700 in forum mel PIC BASIC Pro
    Last Post: - 22nd February 2009, 21:41
  3. 18F8722 sample code
    By George in forum mel PIC BASIC Pro
    Last Post: - 19th June 2008, 14:42
  4. Sample code for pwm
    By Md.Shah in forum mel PIC BASIC
    Last Post: - 10th October 2006, 17:59
  5. 12F675 code sample
    By marad73 in forum mel PIC BASIC Pro
    Last Post: - 23rd May 2006, 14:53
