Cannot get comparator to work in PIC16F887
Results 1 to 8 of 8
    Aug 2014
    Denmark
    Default Cannot get comparator to work in PIC16F887
    Hi - I am new in programming PIC device and I have a project where I need to use one of the two Comparators in PIC16F887
    I have read the datasheet several time but is still unsure about setting up the port - hope someone can come with an solution.
    in my project I use tree 7 segment display so I use interrupt to make them work and its works fine.
    I do not know for sure if this gives problem for my comparator!?
    (I use Pascal as my sw)
    - interrupt setup:
    Procedure interrupt;
    begin
    PORTB := 0;
    PORTD := ciffer[v] + blink_on;
    PORTB := zz; // turn on appropriate 7seg. display
    v := v + 1;
    zz := zz shr 1;
    if zz = 16 then zz := 128; // 4 // prepare mask for digit
    if v > 2 then v := 0; // 3 disp. // turn on 1st, turn off 2nd 7seg.
    TMR0 := 0;
    INTCON := $20;
    end;
    and my setup for the comparator:
    ANSELH := 0;
    // setup Port A :
    TRISA :=%11011111; // input execp bit A5 - used for output for comparator
    ANSEL :=%00001001; // bit A0 and A3 analog = input for comparator
    CM1CON0 :=%11100000; // Comparator C1 enabled
    SRCON :=%00000000; // no latch enabled
    VRCON :=%00100000; // no v ref. enabled
    this is the correct setting for comparator as best I know - but not sure because it not work.
    here is the code where I retrieve the output
    If portA.5=1 then ...
    Can any help ? - do I need to do something for getting the the output
    Best regards Erik Nielsen, Denmark.
    Default Re: Cannot get comparator to work in PIC16F887
    I deleted your other post, in the future only post the same question once. No need to duplicate.
    And
    This forum deals with Pic Basic Pro. You may not get an answer for your question here.
    As far as I can see comparator 1's output is on PortA.4 - not PortA.5.
    And, if you're not actually driving anything with the comparator you don't need to have it "connected" to the physical output. In order to get its state you might as well read CM1CON0.6 (the C1OUT bit).
    Aug 2014
    Denmark
    Thanks for your answer - the PortA.5 was a typo error - I use PortA.4 in my sorce - I do not need to use the pin to read the result - only intern in pic but when that don't work I was trying to get it on a pin so it was visable on my develebment board.
    - can you tell me if my setup of the comparator look ok ?
    Best regards Erik
    Aug 2014
    Denmark
    Just want to tell you that I get it to work now - there was nothing wrong in my code but the PIC I used was damaged - when trying new pic all works fine - thanks again
    Regrads Erik
    Aug 2014
    Denmark
    Sorry for making two question, the first I make look like something went wrong - that why I posted again.
    reg. pic basic pro: when I not use that sw to develobment, then I cannot use your forum ?
    Quote Originally Posted by ErikOdinsvej View Post
    You are more than welcome to post on this forum, I just wanted to point out that you may not get the best answers here when using another compiler.
    Aug 2014
    Denmark
    Just want to tell you all that it to work now - there was nothing wrong in my code but the PIC I used was damaged - when trying new pic all works fine - thanks again
    Regrads Erik
  1. Replies: 2
    Last Post: - 31st May 2013, 18:19
  2. help with pic16f887
    Last Post: - 11th December 2010, 21:38
  3. PIC16F887 and DS1307
    By menta in forum General
    Last Post: - 29th September 2008, 17:05
  4. PIC16F887, turn off..
    By xobx in forum mel PIC BASIC Pro
    Last Post: - 18th October 2007, 05:55
